ionut20 Posted November 16, 2008 Share Posted November 16, 2008 Am si eu nevoie de schema la acest televizor .. m-a lasat in dimineata asta .. la pornire se aude un tiuit din interior, banuiesc ca sursa intra in protectie, probabil vrun tranzistor e puscat .. dar fara schema nu prea vreau sa ma pun sa vad ce are prin interiorSamsung CK-3339Z s/n: 873331CG800155 made in Korea scrie pe eticheta din spate.Multumesc anticipat. Quote Link to comment Share on other sites More sharing options...
Nonny149 Posted November 16, 2008 Share Posted November 16, 2008 Am si eu nevoie de schema la acest televizor .. m-a lasat in dimineata asta .. la pornire se aude un tiuit din interior, banuiesc ca sursa intra in protectie, probabil vrun tranzistor e puscat .. dar fara schema nu prea vreau sa ma pun sa vad ce are prin interiorSamsung CK-3339Z s/n: 873331CG800155 made in Korea scrie pe eticheta din spate.Multumesc anticipat.sper sa se potriveasca schema asta. Quote Link to comment Share on other sites More sharing options...
ionut20 Posted November 16, 2008 Author Share Posted November 16, 2008 multumesc pentru promptitudine ... voi desface televizorul si sa speram ca schema este cea buna la ce am eu in tv. Quote Link to comment Share on other sites More sharing options...
bogdan546 Posted November 16, 2008 Share Posted November 16, 2008 Vezi c851 din sursa inainte de aschimba tranzistori Quote Link to comment Share on other sites More sharing options...
tv1 Posted November 16, 2008 Share Posted November 16, 2008 Chassis : SCT13BModel: CK3339ZR4X/BWT CK5039ZR4X/BWT CK5339ZR4X/BWT Quote Link to comment Share on other sites More sharing options...
ionut20 Posted November 17, 2008 Author Share Posted November 17, 2008 multumesc pentru raspunsuri ... azi am desfacut televizorul, schema s-a potrivit, doar ca in televizor ... o parte din sursa a fost refacuta se pare acu ceva timp, caci in loc de KA250680 prezent in sursa, deasupra cablajului a adaugat cineva un cablaj "home made" ce contine un controler smps, componentele necesare acestuia si un buz90A de unde se pleaca cu fire catre transformatorul din sursa. Dupa o curatare si o inspectie vizuala nu am gasit nimic aparent ars. Am verificat mai apoi tranz final de linii, dar acesta era ok, iar cu el scos de pe cablaj sursa tot se chinuia sa porneasca dar facea acel tiuit tipic la o intrare in protectie. Dupa care facand cateva masuratori in zona transformatorului din sursa, surpriza .. televizorul a pornit. Am zis ca e vb de ceva contacte imperfecte, si in consecinta am refacut toate lipiturile posibile. La urmatoare conectare la retea, la fel .... nu porneste sursa. Dupa mi-a venit idea de a incalzi cateva secunde cu feonul, regiunea sursei, si televizorul a pornit . . . Singura piesa ce zic ca ar fi posibil devalorizata e condensatorul C801 de 220uF la 400V. Masurati pe el am 317V in loc de 330 cat ar fi trebuit calculand cu tensiunea de la retea din momentul masurarii .... plus ca partea superioara e usor umflata, dar putin de tot. Credeti ca incalzind cu feonul sursa, televizorul ar porni in cazul in care acest cond ar fi defectul?Pana una alta televizorul funtioneaza perfect atat timp cat e in priza. Ieri a fost oprit din buton, si la urmatoarea pornire nu a vrut sa plece. Din standby porneste normal de fiecare data. Quote Link to comment Share on other sites More sharing options...
HORIACN Posted November 17, 2008 Share Posted November 17, 2008 multumesc pentru raspunsuri ... azi am desfacut televizorul, schema s-a potrivit, doar ca in televizor ... o parte din sursa a fost refacuta se pare acu ceva timp, caci in loc de KA250680 prezent in sursa, deasupra cablajului a adaugat cineva un cablaj "home made" ce contine un controler smps, componentele necesare acestuia si un buz90A de unde se pleaca cu fire catre transformatorul din sursa. Dupa o curatare si o inspectie vizuala nu am gasit nimic aparent ars. Am verificat mai apoi tranz final de linii, dar acesta era ok, iar cu el scos de pe cablaj sursa tot se chinuia sa porneasca dar facea acel tiuit tipic la o intrare in protectie. Dupa care facand cateva masuratori in zona transformatorului din sursa, surpriza .. televizorul a pornit. Am zis ca e vb de ceva contacte imperfecte, si in consecinta am refacut toate lipiturile posibile. La urmatoare conectare la retea, la fel .... nu porneste sursa. Dupa mi-a venit idea de a incalzi cateva secunde cu feonul, regiunea sursei, si televizorul a pornit . . . Singura piesa ce zic ca ar fi posibil devalorizata e condensatorul C801 de 220uF la 400V. Masurati pe el am 317V in loc de 330 cat ar fi trebuit calculand cu tensiunea de la retea din momentul masurarii .... plus ca partea superioara e usor umflata, dar putin de tot. Credeti ca incalzind cu feonul sursa, televizorul ar porni in cazul in care acest cond ar fi defectul?Pana una alta televizorul funtioneaza perfect atat timp cat e in priza. Ieri a fost oprit din buton, si la urmatoarea pornire nu a vrut sa plece. Din standby porneste normal de fiecare data.daca ai tda4605 in sursa schimba condensat de 1 micro si cel de 47 sau 100 micro Quote Link to comment Share on other sites More sharing options...
ionut20 Posted November 17, 2008 Author Share Posted November 17, 2008 da sunt prezente cele 2 cond in sursa pe placa aceea adaugata ... integratul am uitat sa ma uit ce e ... dar cele 2 cond sunt acolo. Quote Link to comment Share on other sites More sharing options...
Mihai85 Posted November 17, 2008 Share Posted November 17, 2008 schimba cei 2 condensatori de 1uF si de 47uF si o sa mai gasesti niste rezistente de cateva sute de kohmi pe care sa le verifici sa nu fie devalorizate. Quote Link to comment Share on other sites More sharing options...
ionut20 Posted November 18, 2008 Author Share Posted November 18, 2008 Multumesc de ajutor la toti am schimbat cei doi cond. de 1uF si cel de 47uF, si am refacut toate lipiturile din partea de sunet ... pentru ca se auzea cateodata mult mai incet decat ar trebui, si acum merge perfect. Rezistentele nu erau devalorizate, iar placuta atasata pe sasiu era exact ca in datasheetul de la TDA406, tda-ul fiind prezent si el evident.Am testat de cateva ori oprirea din buton, si lasat cateva minute sa se raceasca, si a pornit de fiecare data corect la recuplarea la retea.Inca o data multumesc pentru scheme si sfaturi. :bere: Quote Link to comment Share on other sites More sharing options...
alex_serv57 Posted February 25, 2014 Share Posted February 25, 2014 Salutare .Detine cineva schema acestui tip de tv ?pe scurt :ce ar putea face ca pe B+ sa apara o tensiune mai mare 200 volt ? Quote Link to comment Share on other sites More sharing options...
santamihai Posted February 25, 2014 Share Posted February 25, 2014 http://elektrotanya.com/samsung_sct13b_ ... nload.html Quote Link to comment Share on other sites More sharing options...
alex_serv57 Posted February 25, 2014 Share Posted February 25, 2014 Tv rezolvat problema condensatorul de 22 uf din sursa , si un rezistor de 100k .P.S. Schema nu prea coincide cu tv-ul meu , oricum multumesc pt. schema .Va salut Quote Link to comment Share on other sites More sharing options...
Join the conversation
