RoCky93 Posted November 13, 2008 Share Posted November 13, 2008 am un televizor philips,si are o problema..il deschid,merge el cat merge si apoi se inchide singur si se deschide(tot singur) pe acelasi program foarte repede(inchis deschis cam o data la 2-3 sec)..si face asa destul de mult timp.il inchid de la "buton" cateva minute(chiar zeci) si apoi functioneaza normal...nu stiti ce problema ar putea avea?este dificil de rezolvat? Link to comment
RoCky93 Posted November 14, 2008 Author Share Posted November 14, 2008 ma poate ajuta cineva? Link to comment
trinetservice Posted November 14, 2008 Share Posted November 14, 2008 ma poate ajuta cineva? viewtopic.php?f=17&t=12666 Link to comment
RoCky93 Posted November 14, 2008 Author Share Posted November 14, 2008 nu stiu nimic din toate acestea...dar nu va puteti da cu parerea ce ar putea fi defect de se intampla asta? Link to comment
codrin Posted November 14, 2008 Share Posted November 14, 2008 ai nimerit gresit. ne pricepem in ale electronicii, in ale depanarii radio-tv etc, insa nu ghicim in stele, in carti,in bobi sau alte cele...ptr a afla ce tv ai tu acasa. incearca la MAMA OMIDA SRL. nu crezi,ca ptr a primi ajutorul ce-l ceri , trebuie sa dai informatii amanuntite plus sa respecti regulile acestui forum?! "am un televizor philips" sa-l stapanesti sanatos! altceva nu ne spui( model, sasiu, componente) ...???? astepti sa ghicim noi ( din sutele de modele facute de PHILIPS) cam ce tip de TV este, plus ce este defect in el?. Link to comment
RoCky93 Posted November 14, 2008 Author Share Posted November 14, 2008 Philips 21PT1967/58 Link to comment
tv1 Posted November 14, 2008 Share Posted November 14, 2008 Este sasiul L01.2E AA.Daca nu ai lipituri reci pe pinii trafo linii (cred ca nici nu i-ai desfacut capacul) mai mult ca sigur e tubul prost. Link to comment
RoCky93 Posted November 14, 2008 Author Share Posted November 14, 2008 Este sasiul L01.2E AA.Daca nu ai lipituri reci pe pinii trafo linii (cred ca nici nu i-ai desfacut capacul) mai mult ca sigur e tubul prost.nu am umblat in el...nu l-am desfacut deloc pana acum.tubul e prost?ce ii pot face? Link to comment
tv1 Posted November 14, 2008 Share Posted November 14, 2008 Si ce astepti ? Sa ti-l desfac eu ? Desfa-l ,refa-i lipiturile la trafo linii,daca nu merge, il arunci la gunoi sau te duci cu el la magazin ca-ti dau astia 15% reducere daca o sa cumperi altul. Link to comment
RoCky93 Posted November 14, 2008 Author Share Posted November 14, 2008 Si ce astepti ? Sa ti-l desfac eu ? Desfa-l ,refa-i lipiturile la trafo linii,daca nu merge, il arunci la gunoi sau te duci cu el la magazin ca-ti dau astia 15% reducere daca o sa cumperi altul. cred ca nu m-am exprimat destul de clar incat sa intelegeti problema.acum televizorul merge(se vede foarte clar,totul e ok),dar cateodata incepe sa se stanga si sa se aprinda singur foarte repede :|...asta se intampla o data la cateva zile.Daca ar fi tubul stricat asa s-ar intampla?culorile nu ar fi afectate? Daca lipiturile de la trafo linii nu ar fi bune(asta cred ca este motivul din cele 2 motive date) nu s-ar intampla asta mai des?...ma gandesc nu cumva sa fie stricat altceva...maine voi desface carcasa si voi reface lipiturile.PS:daca va dati seama care ar fi o posibila problema,da-ti un reply ...multumesc Link to comment
dosa Posted November 15, 2008 Share Posted November 15, 2008 poti avea contace imperfecte in mai multew zone, ex in comanda finalului linii, prefinalului linii...etc... Link to comment
Guest tmdmitza Posted November 19, 2008 Share Posted November 19, 2008 mai frate refa toate lipiturile din zonele calde si mai vorbim dupa aceea dak mai ai probleme posteazale aici si se rezolva dar refa odata lipiturile alea..... Link to comment
