dan-a2 Posted November 10, 2008 Share Posted November 10, 2008 va rog frumos ce telecomanda sa cumpar la un golstar ckt 9742 procesor saa 1293, am cumparat una din ploiesti cod 1611 sinu merge deloc cred ca e defecta nu merge nici pe radio Quote Link to comment Share on other sites More sharing options...
gabiTV Posted November 10, 2008 Share Posted November 10, 2008 ptr saa2193 merge p1611, p1679 etc Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted November 11, 2008 Author Share Posted November 11, 2008 da codul e bun = telecomanda defecta de noua !!!! multumesc o sa ma duc sa o schimb Quote Link to comment Share on other sites More sharing options...
Guest cosmynutzaa Posted November 12, 2008 Share Posted November 12, 2008 o sa radeti de problema mea....dar chiar am nevoie de ajutor!Am primit un televizor AKAI,si nu pot sa memorez canalele din telecomanda.Le gasesc,le reglez si nu pot sa le memorez.Ma poate ajuta cineva? :cry: Quote Link to comment Share on other sites More sharing options...
gabiTV Posted November 12, 2008 Share Posted November 12, 2008 ce model? Quote Link to comment Share on other sites More sharing options...
Guest cosmynutzaa Posted November 13, 2008 Share Posted November 13, 2008 RC-N2A.Cand apas MENU imi apar 3 optiuni;AUTOSEARCH,AUTO PROGRAM SI MANUAL TUNE.Daca ii dau AUTO SEARCH le cauta,le gaseste si cand termina si incerc sa vad ce a gasiit,nu se vad bine deloc.Daca dau MANUAL TUNE,le gasesc,se vad super dar nu am cum sa le memorez. :cry: Nu gasesc nici un buton OK. Quote Link to comment Share on other sites More sharing options...
tv1 Posted November 13, 2008 Share Posted November 13, 2008 Se memoreaza cu unul din butoanele colorate ,parca verde. Quote Link to comment Share on other sites More sharing options...
Guest cosmynutzaa Posted November 13, 2008 Share Posted November 13, 2008 Nu merge.Cred ca trebuie sa cumpar o telecomanda universala...daca o sa gassesc asa ceva pt el. Quote Link to comment Share on other sites More sharing options...
tv1 Posted November 13, 2008 Share Posted November 13, 2008 Nu merge.Cred ca trebuie sa cumpar o telecomanda universala...daca o sa gassesc asa ceva pt el. Telecomanda AKAI 21WKDT link Quote Link to comment Share on other sites More sharing options...
Guest cosmynutzaa Posted November 14, 2008 Share Posted November 14, 2008 Multumesc mult TV1! Quote Link to comment Share on other sites More sharing options...
Join the conversation
