eugenchis Posted November 10, 2008 Share Posted November 10, 2008 va salut ,am un tv roadstar primit din italia echipat cu procesor ST92195 si jungla STV2246 , eu sunt un amator si as dori sa intreb daca sunetul nu functioneza decit in norma "BG", cum as putea intra in service mod pentru ai seta si norma "DK"telecomanda care o folosesc este de la tv EUROCOLOR . va multumesc mult. Quote Link to comment Share on other sites More sharing options...
gabiTV Posted November 10, 2008 Share Posted November 10, 2008 meniu 4-7-2-5 Quote Link to comment Share on other sites More sharing options...
eugenchis Posted November 10, 2008 Author Share Posted November 10, 2008 va rog putin mai explicit multumesc mult Quote Link to comment Share on other sites More sharing options...
zvasile Posted November 10, 2008 Share Posted November 10, 2008 apesi de pe telecomanda tastele meniu 4-7-2-5,cu tv pornit bineinteles. Quote Link to comment Share on other sites More sharing options...
tv1 Posted November 10, 2008 Share Posted November 10, 2008 Probabil ca e sasiu 11AK30 (daca e diagonala 51-54 cm) sau 11AK36 (37 cm).Dupa ce intri in service mode cu secventa Meniu,4,7,2,5 selectezi cu tasta PR+ sau PR - parametrul OP2.Apoi apesi tasta 4 pentru a schimba valoarea bitului 4 din 0 in 1.Iesi din service mode apasind tasta Meniu de 2-3 ori .In meniul de cautare o sa iti apara acum si norma DK.(la Standard).Mai trebuie doar sa inlocuiesti FUS-ul (la tine e un G1962,1968 etc.) cu unul binorma gen:K2960;K2962;K2966;K2971 etc. Quote Link to comment Share on other sites More sharing options...
eugenchis Posted November 11, 2008 Author Share Posted November 11, 2008 multumesc tuturor (special TV1). Quote Link to comment Share on other sites More sharing options...
Join the conversation
