galacticul Posted November 7, 2008 Share Posted November 7, 2008 Este un model P2150MTS.Tv functioneaza dar din cand in cand apar descarcari la trafo linii.As vrea sa-l inlocuiesc traf-ul(FUY20B104 Samsung T151005).Detin doua traf-uri recuperate,pe unul scrie Z4344511 HH05LY si pe celalalt KF4867.Rog,cine poate sa ma ajute sa fac modificarile daca e posibil Quote Link to comment Share on other sites More sharing options...
codrin Posted November 7, 2008 Share Posted November 7, 2008 traful echivalent celui de ORION este HR8768 poti sa cumperi un FBT8768 de la: http://www.mivarom.ro/catalog/advanced_ ... 2&x=54&y=5 celelalte n-au echiv HR(dupa codurile date) Quote Link to comment Share on other sites More sharing options...
MifTy Posted May 2, 2010 Share Posted May 2, 2010 ... are idee careva pe unde aş găsi schema tv-ului ăsta???aka orion model p2150mts ... Quote Link to comment Share on other sites More sharing options...
tv1 Posted May 2, 2010 Share Posted May 2, 2010 Sasiu PT90, scheme,diferite versiuni: Problema televizor Orion model P2135 MT link schema Orion P2035MT link schema Schema pentru Orion P2040MTS link schema Tv Orion P2135 MT link schema schema orion model t2155 mtx link schema tv Pionier sasiu PT90 link schema Orion model P2110MT_PT90 schema link schema Tv Orion P2166 MTS link schema http://www.eserviceinfo.com/downloadsm/ ... 20ECO.html http://www.eserviceinfo.com/downloadsm/ ... 02PIP.html http://www.eserviceinfo.com/downloadsm/ ... SONIC.html http://www.eserviceinfo.com/downloadsm/ ... uesky.html http://www.eserviceinfo.com/downloadsm/18513/_.html http://www.eserviceinfo.com/downloadsm/ ... star_.html Quote Link to comment Share on other sites More sharing options...
Guest bdorin Posted September 8, 2011 Share Posted September 8, 2011 Buna, sunt din Oradea si am o problema la un televizor ORION P 2150MTS, daca il tin deschis de la buton sa stea cu ledu pornit sa il poti porni din telecomanda, se porneste singur am crezut ca ii problema de la unghiurile cum are vecinu televizorul si cand muta el se muta si la mine lam mutat in alt loc al camerei, si tot asa se muta pe toate posturile si nu mai sta intr-un loc, va rog frumos sa imi spuneti cam ce ii de facut, chiar de cateva minute am sunat la o firma de reparatii TV si cred ca o sa il duc maine, eu am lucrat in domeniu dar nu mam mai ocupat de mult timp de electornice, cam dupa dumnevoastra ce sa intamplat cu el.Astept un raspuns va multumesc anticipat. Quote Link to comment Share on other sites More sharing options...
bobo Posted September 8, 2011 Share Posted September 8, 2011 aveti tasta program + sau - blocata din bord sau telecomanda.programele cresc sau descresc? trageti singur concluzia care e blocata.de la vecini nu poate fi pt ca telecomanda emite in infrarosu(nu trece prin pereti) nu ca cele auto care emit in radiofrecventa.scoateti bateriile din telecomanda pt a vedea daca dispare defectul.daca nu schimbati butonul din tastatura tv. Quote Link to comment Share on other sites More sharing options...
Guest bdorin Posted September 9, 2011 Share Posted September 9, 2011 aveti tasta program + sau - blocata din bord sau telecomanda.programele cresc sau descresc? trageti singur concluzia care e blocata.de la vecini nu poate fi pt ca telecomanda emite in infrarosu(nu trece prin pereti) nu ca cele auto care emit in radiofrecventa.scoateti bateriile din telecomanda pt a vedea daca dispare defectul.daca nu schimbati butonul din tastatura tv.Nu dispare problema si eu am zis la inceput, ca asta ar fi problema din telecomanda, programele descresc, incepe AV, 99, 98...1, 0, AV....99, si tot asa dar merge nu poti sa il controlezi, ii problema tehnica din el aia 100% stiu doar ca eu mam lasat de electronica la tvurile cu TUB de vreo 2 ani dar uite acuma am nevoie eu pentru mine si is la pamant cu, cunostiintele. Quote Link to comment Share on other sites More sharing options...
leoncris Posted September 9, 2011 Share Posted September 9, 2011 Schimba TOATE "butoanele " de pe panoul frontal al TV_ului.Verifica stabilitatea tensiunilor pe sursa , in special cea de 5V. Quote Link to comment Share on other sites More sharing options...
Guest bdorin Posted September 9, 2011 Share Posted September 9, 2011 Schimba TOATE "butoanele " de pe panoul frontal al TV_ului.Verifica stabilitatea tensiunilor pe sursa , in special cea de 5V.Va multumesc foarte mult de sfat, acelasi sfat lam primit de la colegu meu electronist de meserie ii plecat la munca in Ungaria la RIM(Blackberry) si el o zis ca daca nu au fost folosite se defecteaza, deoarece eu chiar nu le-am folosit deloc ca folosesc telecomanda, problema ii ca trebuie mutat sasiul mai in fata ca sa pot macar sa le decuplez butoanele pana o sa vina el sau o sa il duc la colegi de le Xpert Service, va spun sincer nu mai am nici o aparatura, mam lasat de meserie mam bagat mai mult pe web design si optimizare SEO si am ramas in urma cu electronica, inca odata va multumesc foarte mult acest forum mi-a fost foarte de mult ajutor. Quote Link to comment Share on other sites More sharing options...
Guest anton ioana Posted October 26, 2015 Share Posted October 26, 2015 buna ziua am si eu un orion p2150mts si am uitat parola pt. blocare acces copii. va rog poate sa ma ajute cine sa l deblochez, va multumesc Quote Link to comment Share on other sites More sharing options...
Guest Eugen-Mirela Sidor Posted January 24, 2016 Share Posted January 24, 2016 Am un televizor ORION K2145mt cu TDA9345ps si am nevoie de o schema.Ma puteti ajuta? Quote Link to comment Share on other sites More sharing options...
tehtronics Posted January 24, 2016 Share Posted January 24, 2016 Asta e ceva sasiu BEKO(vezi ceva marcaje pe cablaj...) Spune procesorul complet, cu terminatie Quote Link to comment Share on other sites More sharing options...
leoncris Posted January 24, 2016 Share Posted January 24, 2016 (edited) E1 ? http://monitor.espec.ws/section1/topic164936.html Edited January 24, 2016 by leoncris Quote Link to comment Share on other sites More sharing options...
Sorin Schiriac Posted January 24, 2016 Share Posted January 24, 2016 schema beko E1 BEKO chassis E1.rar Quote Link to comment Share on other sites More sharing options...
adydep Posted January 24, 2016 Share Posted January 24, 2016 Ce deranjamente prezinta aparatul? Quote Link to comment Share on other sites More sharing options...
Join the conversation
