chanito Posted April 7, 2008 Share Posted April 7, 2008 salutare stimabililor,am un tv Hyundai ,chinezarie ,cu sasiu beko kx1.190-11.are in sursa ICE 1QS01.am nevoie de o schema ,dar nu gasesc dupa codul asta.daca stie cineva..... Link to comment
chanito Posted April 7, 2008 Author Share Posted April 7, 2008 revin .am gasit echivalenta ,este k1.dar nu l-am gasit nici pe E-SERVICEinfo.NU PORNESTE SURSA .VERIFICAT C.I (INLOCUIT).AM NEVOIE DE O SKEMA :prayer: Link to comment
tv1 Posted April 7, 2008 Share Posted April 7, 2008 Schema (in service manual) aici: http://forum.microprocesoare.ro/index.php?topic=119.0 Link to comment
chanito Posted April 7, 2008 Author Share Posted April 7, 2008 sarumana :partyman: :supz: :smt020 Link to comment
Guest RUZIK41 Posted April 7, 2008 Share Posted April 7, 2008 Am intirziat, dar poate o sai prinda bine la altcineva. Link to comment
chanito Posted April 7, 2008 Author Share Posted April 7, 2008 mersi tuturordar problema nu s-a rezolvat.are tensiune de start si alimentare,dar sursa nu porneste.ca si cum ar fi blocata din exterior.am tot verificat secundarele,linile.,etc.a mai lucrat cineva modelulasta?un tips ar fi binevenit.plus ca pe schema e o rez. de 27r,iar pe sasiu e de 68k(r637).ciudatel rau acest sasiu :rock: :smt021 Link to comment
chanito Posted April 8, 2008 Author Share Posted April 8, 2008 da.i-am schimbat mcr si a inceput sa oscilese sursa.scoate tensiuni ,inclusiv cea de B+ care e 136v(115v normal),dar nu pleaca de pe standby,si are si un huruit usor.mare porcarie.va tin la curent(300 dc :weedman: ) Link to comment
Guest RUZIK41 Posted April 9, 2008 Share Posted April 9, 2008 tv1, multumesc pentru linc. Am vazut ca mai multe pozitii din linc nu sint in documentul meu, si o pozitie sau doua din documentul meu nu sint in linc. Din doua am facut unul, mia prinde bine. chanito, folosestete de un esr-metru, poate sa te ajute in cautarea defectului dat. Link to comment
chanito Posted April 10, 2008 Author Share Posted April 10, 2008 nam.dar am o halba mai mare si mai frumoasa ca a ta! :rock: dupa ce l-am mai pigulit,se pare ca el pleaca de pe standby dar intr-o stare intermediara.cu tensiunile putin diferite.si apropo schema nu e identica cu sasiul.in principiu e aceias dar difera notatiile pieselor.ar putea fi de la memorie?stiu ca genul asta de one single chip nu pornesc daca sesizeaza ceva defect.partea de cadre si linii e in regula.daca stie careva cum se comporta acest gen de proc.as ramine indatorat.mersi TV1 pt.lincuri. Link to comment
Guest RUZIK41 Posted April 11, 2008 Share Posted April 11, 2008 chanito, halba ta poate e mai mare si mai frumoasa, dar a mea e fermecata, se impla singura cind spun cuvintul fermecat. Despre defect - eu as controla tubul, daca tot nu ai cu ce, poti pur si simplu sa il scimbi pentru a micsora zona defectelor posibile. Link to comment
tocavali Posted February 8, 2012 Share Posted February 8, 2012 cum a-ti rezolvat cu sasiul kx1-190-...?Am si eu aceeasi problema, toate tensiunile sunt bune dar nu pleaca, nici procesorul nu da semne. Link to comment
BUGHIU Posted February 8, 2012 Share Posted February 8, 2012 Dar schema asta nu va ajuta mai mult? Schimbati si IC609(TL431),eventual verifiati sursa pe bec/rezistenta sa vedeti face st-by;pornit ,oprit!! http://www.electronica-pt.com/index.php ... no_html,1/ Link to comment
