b_daniel Posted February 13, 2008 Share Posted February 13, 2008 Nu am putut sa identific sasiul. E construit cu TDA9361PS/N2, 24c08, TDA8357 cadre, sursa cu BO352 parca.Am avut memorie defecta,fara rastru, am inlocuit-o cu una goala, merge bine dar memorarea o face alaturi de post .Daca fac acord fin am culoare si sunet bun. Trebuie sa scriu memoria? Cu ce dump?Multumesc. Quote Link to comment Share on other sites More sharing options...
codrin Posted February 13, 2008 Share Posted February 13, 2008 uite ca au rusii astia si dumpuri ptr HT 2199 uite adresa: http://master-tv.com/proshivki/tv/Haier ... -dump.html sper sa-ti fie de folos. succes! da-ne de stire daca ai rezolvat-o cu vreun dump rusesc. Quote Link to comment Share on other sites More sharing options...
b_daniel Posted February 14, 2008 Author Share Posted February 14, 2008 Din pacate nu a mers. Dumpurile sunt pentru sasie cu LAxxxx,LCxxxxx si nu ptr tda9361.Nu mai inteleg :smt017 astia au bagat diverse sasie in cutii cu acelasi model??Poate mai aveti voi alte dumpuri :prayer: Quote Link to comment Share on other sites More sharing options...
cornel_v2005 Posted October 11, 2013 Share Posted October 11, 2013 Salut tuturor! La acelasi model de Haier HT2199 precizat mai sus:procesor TDA9361/ps/n2/5i si memorie 24lc08 (24c16) 2kbas avea nevoie de un dump bun si cum intru service menu de pe telecomanda. Am deregari de dimensiune verticala. Initial nu puteam porni deloc TV-ul dar am pus o memorie goala si am reprogramat pe auto dar se oprea pe alb negru, nu pe culoare. As aprecia orice fel de ajutor! Multumesc Quote Link to comment Share on other sites More sharing options...
cornel_v2005 Posted October 11, 2013 Share Posted October 11, 2013 Am uitat sa spun ca nu merg dumpurile de la siteul acela rusesc de mai sus Quote Link to comment Share on other sites More sharing options...
dan cod Posted October 11, 2013 Share Posted October 11, 2013 Incearca cu astea. Quote Link to comment Share on other sites More sharing options...
iuliantv Posted October 11, 2013 Share Posted October 11, 2013 http://dump.elektroda.pl/download12038.html Quote Link to comment Share on other sites More sharing options...
cornel_v2005 Posted October 11, 2013 Share Posted October 11, 2013 Incearca cu astea. Multumesc a mers mai bine cu al dvs insa dimensiunea verticala aproape ok. Meniu service cum intru si ies? Quote Link to comment Share on other sites More sharing options...
cornel_v2005 Posted October 11, 2013 Share Posted October 11, 2013 Am reusit sa gasesc service manual, am intrat in meniu service cu "mute" + "call" + "-/--" dar nu pot iesi. am incercat cu power off atat din telecomanda si tv si la repornire sunt mereu in service menu... sugestii? Quote Link to comment Share on other sites More sharing options...
cornel_v2005 Posted October 11, 2013 Share Posted October 11, 2013 In sfarsit am iesit cu "EXIT" de pe telecomanda. acum e totul ok. Multumesc colaboratorilor de pe acest site! Quote Link to comment Share on other sites More sharing options...
Join the conversation
