eugenchis Posted January 31, 2008 Share Posted January 31, 2008 va salut . am un tv. akai cu sursa TDA-16846,SDA 5535 MN5198 vertical AN5539 lovit de trasnet din vara , tv-ul porneste cu pureci ,as dori o schema daca ma puteti ajuta si cum se poate intra in meniul service.multumesc mult si va ramin recunoscator. Quote Link to comment Share on other sites More sharing options...
mariancalinescu Posted January 31, 2008 Share Posted January 31, 2008 Tv-ul tau este un Beko sasiu 12.6. Quote Link to comment Share on other sites More sharing options...
Nonny149 Posted January 31, 2008 Share Posted January 31, 2008 uite schema de care ai nevoie.bafta. Quote Link to comment Share on other sites More sharing options...
eugenchis Posted February 2, 2008 Author Share Posted February 2, 2008 multumesc Nonny 149 dar nu ai schema in ce mi-ai trimis,poate ma ajuti cred ca este sasiul Beko 12.6 Quote Link to comment Share on other sites More sharing options...
tv1 Posted February 2, 2008 Share Posted February 2, 2008 Beko sasiu 12.6_schema si sm sm este pentru Grundig 12.6 Quote Link to comment Share on other sites More sharing options...
eugenchis Posted February 3, 2008 Author Share Posted February 3, 2008 multumesc TV1. Quote Link to comment Share on other sites More sharing options...
Join the conversation
