paun nelu Posted January 29, 2008 Share Posted January 29, 2008 nippon ec 14276 ; proc.vct3831a/c4;mem. 24c16.rog cine are un dump sa-mi dea si mie.mersi mult! Quote Link to comment Share on other sites More sharing options...
mircea626 Posted January 29, 2008 Share Posted January 29, 2008 n-am gasit ce vrei,dar incearca dumpul asta Quote Link to comment Share on other sites More sharing options...
tv1 Posted January 29, 2008 Share Posted January 29, 2008 NIPON EC2175 link Quote Link to comment Share on other sites More sharing options...
paun nelu Posted January 30, 2008 Author Share Posted January 30, 2008 NIPON EC2175 linkacelasi simtom pe care il prezinta [fanos]in topicul indicat de d-tra il are tv. meu,acum o luna , o luna si i-am dat retur altui tv dindui verdict proc. cei cert ca nu-s sigur ...cer o parere ; poate fii procu? Quote Link to comment Share on other sites More sharing options...
tv1 Posted January 30, 2008 Share Posted January 30, 2008 Dupa cum am spus acolo eu am dat retur la trei bucati ,toate cu acel simptom:cautare continua pe cele trei benzi,imediat la aproximativ 1 min. de la pornire.Eu am schimbat si memorie,tastatura decuplata etc.(in final am ramas cu ideea ca 99% este VCT-ul;nu am avut de proba asa ca...).Oricum pretul lui e la undeva intre 120-150 lei asa ca te lasi pagubas.Pina acum am auzit foarte multi depanatori vorbind de acest defect,in concluzie e un defect destul de des intilnit pe acest sasiu (ori este IC-ul defect ori poate fi incadrat in categoria ''tips & tricks'' ).Cineva care s-a mai intilnit cu asa ceva ar trebui sa posteze(asta daca nu vrea sa tina doar pt. el rezolvarea acestui defect ). Quote Link to comment Share on other sites More sharing options...
kostel Posted February 16, 2008 Share Posted February 16, 2008 Cum se intra in meniu service la acest tip de tv? Quote Link to comment Share on other sites More sharing options...
kostel Posted February 16, 2008 Share Posted February 16, 2008 Am rezolvatCAPS apoi REVEAL in 3 sec dupa telecomanda si a intrat in meniu service Quote Link to comment Share on other sites More sharing options...
Mesterul Posted October 17, 2012 Share Posted October 17, 2012 Are cineva o schema de sursa la acest model ?Are IC-44608 P 40 si mos K 3115 .Ca sa scot din circuit optocuplorul ce trebuie sa pun in locul diodei lui -pana la depanarea sursei ?(o rezistenta, o dioda...) Astfel incat sa elimin celelalte iesiri din secundarul chopperului .-care alimenteaza si regleaza si optocuplorul . Quote Link to comment Share on other sites More sharing options...
naebv Posted October 17, 2012 Share Posted October 17, 2012 Schema o puteti descarca de aici: http://elektrotanya.com/china_chassis_m ... nload.html Partea dinspre sursa a optocuplorului este pe post de "rezistenta" variabila, comandata de ledul din optocuplor. Deci puteti incerca sa simulati existenta optocuplorului cu un semiregrabil in partea de primar a sursei, de ce valoare nu se stie...In orice caz nu este recomandata simularea optocuplorului. Quote Link to comment Share on other sites More sharing options...
Mesterul Posted October 17, 2012 Share Posted October 17, 2012 Asta e ; Multumesc !Crearea unui cont pe ElectroTanya se face pe baza de invitatie ?As vrea si eu o invitatie ! Quote Link to comment Share on other sites More sharing options...
naebv Posted October 18, 2012 Share Posted October 18, 2012 Nu stiu daca se face in urma unei invitatii. Pentru a descarca pe un calculator max. 2 service manuale pe zi nu este nevoie de cont. Quote Link to comment Share on other sites More sharing options...
Join the conversation
