Guest HORIA C Posted January 28, 2008 Share Posted January 28, 2008 cine are o schema,ma rog la dumneavoastra! Quote Link to comment Share on other sites More sharing options...
Craciun Posted January 28, 2008 Share Posted January 28, 2008 vezi fisier atasat Quote Link to comment Share on other sites More sharing options...
tv1 Posted January 29, 2008 Share Posted January 29, 2008 Doua link-uri despre Delia: Amplituner DELIA Scheme Delia Quote Link to comment Share on other sites More sharing options...
Guest A d i Posted May 5, 2008 Share Posted May 5, 2008 am si eu o mica problema cu amplituneru meu delia...pe o iesire scoate foarte incet, dak dau balansul pe ea abea ca se aude...dak ma poate ajuta cineva va rogmultumesc Quote Link to comment Share on other sites More sharing options...
zal Posted May 5, 2008 Share Posted May 5, 2008 Verifica si inlocuieste C315,316 din preul de tonuri si C405,406 din etajul final. Quote Link to comment Share on other sites More sharing options...
Cobra Posted May 18, 2008 Share Posted May 18, 2008 am o problema la amplitunerul delia dupa ce iam schimbat finali ca erau dusi si un condensator(47uF 40V), pe canalul R merge muzica sacad iar canalul L merge perfect. ce poate sa aiba canalul R? :smt006 Quote Link to comment Share on other sites More sharing options...
Guest A d i Posted February 10, 2011 Share Posted February 10, 2011 Verifica si inlocuieste C315,316 din preul de tonuri si C405,406 din etajul final.Am schimbat acesti condensatori, am schimbat si finali dar nu e nici o diferenta, se aude la fel, cu balans pe partea stanga la maxim si abea se aude ceva.Alte idei? Quote Link to comment Share on other sites More sharing options...
remus68 Posted February 10, 2011 Share Posted February 10, 2011 Daca ai cunostinte de electronica si stii sa lucrezi cu aparate aflate sub tensiune, poti incerca urmatoarea varianta ilustrata in figura alaturata: -Introduci la intrarea amplificatorului un semnal stereo corect aplicat la mufa de intrare a amplificatorului si pozitionezi reglajul de balans pe mijloc. -Realizezi strapul rosu. Daca se aude la fel in cele doua canale, etajul final de putere este bun pe amindoua canalele. Daca se aude necorespunzator, defectiunea se gaseste in etajul final de putere. -Deconectezi strapul rosu si efectuezi strapul verde. Daca se aude la fel in cele doua canale, etajul final de putere si corectorul de ton este bun pe amindoua canalele. Daca se aude necorespunzator, problema este in corectorul de ton. -Deconectezi strapul verde si realizezi strapul galben. Daca se aude la fel in amindoua canalele, amplificatorul functioneaza fara nici o problema, dar nu ai conectat corect sursa de semnal la mufa de intrare. Daca se aude necorespunzator, problema este in preamplificator. Quote Link to comment Share on other sites More sharing options...
Guest A d i Posted April 15, 2011 Share Posted April 15, 2011 Prin strap te referi la un conductor intre zonele care mi le-ai aratat?Cred ca mi-ar fi destu de greu sa gasesc in cablaj acele zone sau nu?Problema ar putea aparea din pricina unui buton? Eu ca sursa de semnal am PC-ul care merge catre intrarea Magnetofon, butonu de actionare sta apasat si nu prea. Quote Link to comment Share on other sites More sharing options...
leoncris Posted April 15, 2011 Share Posted April 15, 2011 Tine "butonul" de mag.apasat si vezi daca ai semnal corect.(Poti chiar sa-l actionezi de cateva ori cu semnalul de la PC cuplat.)Daca ,da inlocuiesti "butonul",sau il scoti si-l cureti. Quote Link to comment Share on other sites More sharing options...
Join the conversation
