codrin Posted January 25, 2008 Share Posted January 25, 2008 salut! la ce sasiu de tvc DAEWOO se foloseste ? am cautat insa momentan imi 'scapa'.seria originala a trafului este KFS60455F Quote Link to comment Share on other sites More sharing options...
tv1 Posted January 25, 2008 Share Posted January 25, 2008 KFS60455C(sau E) merge pe Dynasty model CT-511; Plantron model 5180.Vezi aici:(ai si schema) Crown,Dynasty,Plantron Quote Link to comment Share on other sites More sharing options...
codrin Posted January 26, 2008 Author Share Posted January 26, 2008 MULTUMESC! o zi buna . Quote Link to comment Share on other sites More sharing options...
Guest sorin_vasilache Posted May 20, 2009 Share Posted May 20, 2009 salut! am un traf original nou trf7434 echivalent cu ksf-60455f ....... 0748402187 Quote Link to comment Share on other sites More sharing options...
palcu ion Posted May 20, 2009 Share Posted May 20, 2009 daca doresti iti pot furniza un catalog HR Quote Link to comment Share on other sites More sharing options...
tv1 Posted May 20, 2009 Share Posted May 20, 2009 salut! am un traf original nou trf7434 echivalent cu ksf-60455f ....... 0748402187Te-ai trezit dupa un an de zile de la data ultimei postari. Quote Link to comment Share on other sites More sharing options...
Join the conversation
