Guest HORIA C Posted January 24, 2008 Share Posted January 24, 2008 cine poate sa ma ajute cu o schema,ceva,pentru lumina din casa scarii,dupa ce a fost aprinsa,la un anume interval sa se stinga singura pina la o noua apasare a intreupatorului. e pueril,stiu,dar ma chinui de ceva timp..... niq_ro a modificat titlul, in ce se dorea de fapt Quote Link to comment Share on other sites More sharing options...
nicul Posted January 25, 2008 Share Posted January 25, 2008 gasesti pe site-ul lui niq_ro unul foarte simplu explicat in detaliu Quote Link to comment Share on other sites More sharing options...
Stefan Posted January 25, 2008 Share Posted January 25, 2008 adica un temporizator ! sunt foarte multe variante de scheme dar vorba lui @nicul uite aici http://www.niqro.3x.ro/cs/cs.htm Quote Link to comment Share on other sites More sharing options...
one Posted January 29, 2008 Share Posted January 29, 2008 Se gasesc si gata facute la magazinele de electrice.Se numesc automate de scara si respecta normele de protectie electrica, sunt omologate.Altfel, poti construi tu unul, cauta colectia revistei Tehnium 1980-2000 la biblioteca si vei gasi sigur o gramada de scheme. Quote Link to comment Share on other sites More sharing options...
tiristor Posted February 2, 2008 Share Posted February 2, 2008 sau potio folisi sesizoare circulare la 360gr la fiecare etaj si ai scapat de probleme.se aprind cand sesizeaza persoana care se apropie si se sting dupa ce a trecut. :supz: Quote Link to comment Share on other sites More sharing options...
MiniTehnicus Posted February 8, 2008 Share Posted February 8, 2008 Se gasesc senzori de miscare, simpli sau cu un proiector incorporat.Se poate regla durata cat ramane lumina aprinsa dupa ce simte miscarea si bonus are comutator zi noapte. Quote Link to comment Share on other sites More sharing options...
tiristor Posted February 10, 2008 Share Posted February 10, 2008 Si consumul e infinit de redus,practic zici ca arde doar una ,doua becuri si nu zece. :smt031 Quote Link to comment Share on other sites More sharing options...
1835 Posted February 10, 2008 Share Posted February 10, 2008 In ideea de a nu mai deschide un nou topic,m-am gandit aici sa postez.Exista mai nou niste intrerupatoare mai speciale ,ce se folosesc pe holuri mari.Specialitatea acestor intrerupatoare e ca...de exemplu daca lumina e aprinsa dintr-un capat al holului,acea lumina poate fi strisa din oricare alt intrupator de pe hol.Deci eu aprind de aici ,si celalalt stinge de acolo Aaaa si intrebarea : Cum functioneaza aceste intrerupatoare?Poate si o schema de principiu... Quote Link to comment Share on other sites More sharing options...
Dr.L Posted February 10, 2008 Share Posted February 10, 2008 cu un releu cu n ansamble de 2 intrerupatoare,unul ni unul ndcontatceele nd se pun in paralel,ele pornesc lumina,iar cele ni in serie,ele inchid luminase poate face si electronic treaba asta Quote Link to comment Share on other sites More sharing options...
sofian Posted February 10, 2008 Share Posted February 10, 2008 @1835se poate face cu doua intrerupatoare cu contacte ni si nd Quote Link to comment Share on other sites More sharing options...
Dr.L Posted February 10, 2008 Share Posted February 10, 2008 sau mai multe,pui cate ai nevoie Quote Link to comment Share on other sites More sharing options...
nickrvl Posted February 10, 2008 Share Posted February 10, 2008 In ideea de a nu mai deschide un nou topic,m-am gandit aici sa postez.Exista mai nou niste intrerupatoare mai speciale ,ce se folosesc pe holuri mari.Specialitatea acestor intrerupatoare e ca...de exemplu daca lumina e aprinsa dintr-un capat al holului,acea lumina poate fi strisa din oricare alt intrupator de pe hol.Deci eu aprind de aici ,si celalalt stinge de acolo Aaaa si intrebarea : Cum functioneaza aceste intrerupatoare?Poate si o schema de principiu...Cam asta ar fi schema:[attachment=0]Clipboard02.jpg[/attachment]Comutatoarele le gasesti la electrice, se cheama Cap Scara.Apropo se gasesc si altfel de comutatoare care se cheama Cap Cruce, se folosesc acolo unde e nevoie sa aprinzi un bec din trei locuri diferite. Ex.: Un hol cu trei intrari... Quote Link to comment Share on other sites More sharing options...
tiristor Posted February 11, 2008 Share Posted February 11, 2008 La intrerupatoarele cap cruce ai nevoie de fire in plus,el are 4 contacte si tot atatea fire.Esti mai castigat cu un automat sau sesizopare de miscare. :supz: Quote Link to comment Share on other sites More sharing options...
niq_ro Posted February 15, 2008 Share Posted February 15, 2008 in carte scrisa de dl. Constantin Burdescu, DEPANARI SI REPARATII CASNICE - indrumar practic - volumul II, Editura Tehnica, Bucuresti, 1988 este un articol Circuit de lumina du-te-vino (cap scara) despre care poti citi la http://www.niqro.3x.ro/cs/cs.htm Quote Link to comment Share on other sites More sharing options...
tiristor Posted February 16, 2008 Share Posted February 16, 2008 Acest circuit se foloseste si astazi in apartamente,dar ciscuitul cu 3-4-5 intrerupatoare are cu totul alta scheme. :drinkers: Quote Link to comment Share on other sites More sharing options...
Join the conversation
