grigo53 Posted January 24, 2008 Share Posted January 24, 2008 am si eu o rugaminte:spuneti-mi de unde pot face rost de un tf.linii pentru akai 11ak33 j4?codul original este:13720087b.nu am g2(135v). Quote Link to comment Share on other sites More sharing options...
tv1 Posted January 24, 2008 Share Posted January 24, 2008 Redenumeste si tu titlul topicului (depanari radio-tv ).HR8882: http://www.hrdiemen.es/products/index.p ... HR8882.gif Quote Link to comment Share on other sites More sharing options...
grigo53 Posted January 24, 2008 Author Share Posted January 24, 2008 credeam ca pe acest forum sunt si depanatori tv. Sa inteleg ca nu a avut nevoie, nimeni, de un asemenea tf.?sau este prea scumpa solutia sa o dati pe forumul acesta. imi cer scuze anticipat dar sunt stresat. este vorba de tvul unui vecin , si am scandal in casa(ce fel de electronist esti?). multumesc lui TV1 pentru promtitudine. Quote Link to comment Share on other sites More sharing options...
tv1 Posted January 24, 2008 Share Posted January 24, 2008 Un alt transformator care merge perfect in locul celui cautat de tine este HR80117 folosit pe sasiul 11AK45(echipeaza tv Vestel,Hitachi,JVC,Sharp).Problema e ca,asa cum ai spus si tu aceste transformatoare sint cam scumpe si mai dificil de gasit. http://www.hrdiemen.es/products/index.p ... R80117.gif sau varianta cu dubla focalizare HR80213 folosit tot pe 11AK33 http://www.hrdiemen.es/products/index.p ... R80213.gif Quote Link to comment Share on other sites More sharing options...
mircea626 Posted January 25, 2008 Share Posted January 25, 2008 daca nu reusesti sa adaptezi un alt traf,atunci poti face ug2 culegind tens. de pe colectorul finalului de linii ,redresata filtrata si ajustata cu un potentiometru Quote Link to comment Share on other sites More sharing options...
tv1 Posted January 25, 2008 Share Posted January 25, 2008 Buna idee.Si chiar ieftin de pus in practica. Quote Link to comment Share on other sites More sharing options...
techs Posted January 25, 2008 Share Posted January 25, 2008 nu am g2(135v).Daca nu gasiti transformator sau este prea scump, incearcati sa luati tensiune ptr g2 din colectorul tranz linii , se practica la tv mai vechi, asta daca transformatorul vechi nu are si alte probleme si bleederul nu este intrerupt,Este posibil sa nu mai aveti contact intre cursorul Ug2 si pelicula de carbon. Quote Link to comment Share on other sites More sharing options...
Everest Posted January 25, 2008 Share Posted January 25, 2008 Uite asa: Quote Link to comment Share on other sites More sharing options...
grigo53 Posted January 25, 2008 Author Share Posted January 25, 2008 prefer sa adaptez alt tf. ori sa mai astept. adaptarea propusa de voi este riscanta.daca avea bv. alimentat cu o singura tensiune,montam hr8029 de la ak19.multumesc ,oricum,pt. intelegere.nu stiu de ce am scris hr7950,?scuze. Quote Link to comment Share on other sites More sharing options...
Everest Posted January 25, 2008 Share Posted January 25, 2008 prefer sa adaptez alt tf. ori sa mai astept. adaptarea propusa de voi este riscanta.daca avea bv. alimentat cu o singura tensiune,montam hr7950 de la ak19.multumesc ,oricum,pt. intelegere.De ce este riscant ???Aceasta schema este folosita in multe TV-uri !!!Eu personal am folosit-o la multe TV-uri si mai ales la monitoare.Daca n-ai alta problema la traf ..... n-are rost sa-l schimbi.(parerea mea) Quote Link to comment Share on other sites More sharing options...
cristronic Posted January 25, 2008 Share Posted January 25, 2008 Pot sa-ti trimit eu un traf. nou,daca nu vrei sa faci economie. Quote Link to comment Share on other sites More sharing options...
mariancalinescu Posted January 25, 2008 Share Posted January 25, 2008 Grigo nu poti pune traf 7950 din tv-uri cu diag.<51cm,care se alimenteaza cu U1=115V la tv-ul tau care are U1=150V. Condensatorul placheta care filtreaza Ug2 l-ai schimbat? Quote Link to comment Share on other sites More sharing options...
tv1 Posted January 25, 2008 Share Posted January 25, 2008 1.Nu merge HR7950 pe acest sasiu (11AK33 )e un sasiu la 110 grd ;pe 11AK19-110 grd se foloseste HR8029 uzual si2.Sa te vad eu cum faci + si - 14V pentru baleiaj vertical cu trafo de 11AK19 (nu mai vorbim de pinul 4 pt. E-W ),asta e tv. pretentios nu merge asa usor cu adaptari de trafo.Obtinerea Ug2 din colectorul finalului de linii a fost folosita de firme mari(Philips ,Grundig ,Saba etc.) atunci cind nu existau trafo linii cu diode split pe serii mari de aparate si nu prezinta nici un risc. Quote Link to comment Share on other sites More sharing options...
fen Posted January 25, 2008 Share Posted January 25, 2008 Se poate folosi un blider dintr-un alt traf. Se pun in paralel pipele fit ,se leaga toti pinii de la traful adaugat in scurt si la masa si se duce firul de g2 in locul firului vechi, cel vechi se izoleaza iar firul de la focus la fel se izoleaza si ai rezolvat problema fara sa cumperi un traf scump. Izolarea se face cu bagheta de polietilena topita pe capatul firului(inainte sa faci aceasta operatiune verifica daca nu ai intre pinii condului de la G2 un material maro care conduce si curata bine acolo eventual sa masori condul sa nu fie in scurt sau cu curenti de fuga)Am uitat sa iti spun si eu sa masori daca nu este in scurt condul de la G2 sau are curenti de fuga ,sau poate ai intre pinii condului ceva material care este de culoare maro si trebuie curatat pentru ca acel material conduce curentul am mai intilnit cazuri foarte des si daca cureti o sa mearga din nou fara sa mai trebuiesca altceva Quote Link to comment Share on other sites More sharing options...
grigo53 Posted January 26, 2008 Author Share Posted January 26, 2008 1.Nu merge HR7950 pe acest sasiu (11AK33 )e un sasiu la 110 grd ;pe 11AK19-110 grd se foloseste HR8029 uzual si2.Sa te vad eu cum faci + si - 14V pentru baleiaj vertical cu trafo de 11AK19 (nu mai vorbim de pinul 4 pt. E-W ),asta e tv. pretentios nu merge asa usor cu adaptari de trafo.Obtinerea Ug2 din colectorul finalului de linii a fost folosita de firme mari(Philips ,Grundig ,Saba etc.) atunci cind nu existau trafo linii cu diode split pe serii mari de aparate si nu prezinta nici un risc.ai perfecta dreptate,am modificat astazi(8029),apropo ce masuri de protectie cunoasteti(la bv cu tda8177 sau similare)pt. a preintimpina distrugerea tubului? Quote Link to comment Share on other sites More sharing options...
Join the conversation
