cuuiu Posted January 23, 2008 Share Posted January 23, 2008 problema sursa,STRR S5707,supraalimentat.va rog cine ma poate ajuta cu o schema,pro.sda5255-a035,mem.24c08,tda 8374a,{cer scuze nu stiu corect sasiul}Multumesc mult. Quote Link to comment Share on other sites More sharing options...
Tavi Posted January 23, 2008 Share Posted January 23, 2008 cp375 evident , scrie si pe sasiu daca te uiti , dar na , numai daca te uiti ... :smt017 Quote Link to comment Share on other sites More sharing options...
cuuiu Posted January 23, 2008 Author Share Posted January 23, 2008 multumesc TAVI. Quote Link to comment Share on other sites More sharing options...
Join the conversation
