qazaq Posted January 23, 2008 Share Posted January 23, 2008 buna!am si eu un tv nei cu pip la depanat ,problema initiala a fost ca nu pornea ,dupa ce am rezolvat problema asta am observat ca nu are luminozitate destula,nici cu pot. de la G2 la maxim.matricea este de tip jungla tda8362,finale video tranzistorizate ,tensiunea pe G2 ~300v,tda 8362 s-a inlocuit si tot aceeasi treaba,trf de linii s-a inlocuit dar defectul persista.are cineva o idee ce ar putea fi,schema am gasit ceva asemanator dar fara partea de pip.Va multumesc anticipat. Link to comment Share on other sites More sharing options...
cuuiu Posted January 23, 2008 Share Posted January 23, 2008 verifica BV. Link to comment Share on other sites More sharing options...
qazaq Posted January 23, 2008 Author Share Posted January 23, 2008 fi mai precis te rog,ce anume la BV ar putea afecta luminozitatea?oricum mersi de idee. Link to comment Share on other sites More sharing options...
Tavi Posted January 23, 2008 Share Posted January 23, 2008 nici o legatura , a scris si el asa cred ... :smt017 Link to comment Share on other sites More sharing options...
qazaq Posted January 23, 2008 Author Share Posted January 23, 2008 toate tensiunile sint bune.Am inlocuit condensatori de filtrare pe toate ramurile inclusiv si pe cel de 200v.comenzile da analogice lucra bine,se incadreaza.As mai preciza si faptul ca culoarea OSD-ului este neagra(in loc de verde,rosu,etc). :rolleyes: Link to comment Share on other sites More sharing options...
Mihai85 Posted January 23, 2008 Share Posted January 23, 2008 Sa nu fie tubul dus..Cand dai contrastul la max conturul imaginii este manjit? Link to comment Share on other sites More sharing options...
qazaq Posted January 23, 2008 Author Share Posted January 23, 2008 nu,din contra are un contrast foarte bun.am pus si catozii la masa ,emit f.bine.un lucru e inca interesant ca,si daca dau screenul la maxim nu apare cursa inversa. Link to comment Share on other sites More sharing options...
lulu07 Posted January 23, 2008 Share Posted January 23, 2008 vreun ci comutator....... Link to comment Share on other sites More sharing options...
qazaq Posted January 23, 2008 Author Share Posted January 23, 2008 ci comutator nu prea as crede ca ar fi ,pt. ca semnalul video este prelucrat intern in tda 8362,celelalte semnale de osd,txt,pip sint injectate in rgb, respectiv mixate peste iesirile de matrice,le-am dezlegat pe toate ca sa vad ce se intimpla dar nimic. Link to comment Share on other sites More sharing options...
Nonny149 Posted January 23, 2008 Share Posted January 23, 2008 tensiunea de UG2 e cam mica.daca nu poate fi marita,sant probleme cu bliderul. asta in cazul in care celelalte tensiunii sant corecte. Link to comment Share on other sites More sharing options...
qazaq Posted January 23, 2008 Author Share Posted January 23, 2008 tot atita-i si cu traful original(hr8396),traful de linii s-a inlocuit. Link to comment Share on other sites More sharing options...
tv1 Posted January 23, 2008 Share Posted January 23, 2008 C206 =22nF/1kV-de pe placa TK- filtraj Ug2 are rezistenta (inlocuieste-l) sau C683=47 mF/160V -al doilea filtraj de pe bara B+ uscat posibil si C708=680nF/250V intrerupt.Mai poti verifica si D105,D106=1N4148 si C711=4,7mF(pin 7 ABL trafo linii).Este sasiul E5(fabricat de Gorenje -Evelux din Slovenia) varianta cu PIP.PIP-ul este pe o placa cu teletextul?(TDA9160;TDA4661;SDA9187;SDA9188;CF72306;CF70200 si ST6210). Link to comment Share on other sites More sharing options...
mariand Posted January 23, 2008 Share Posted January 23, 2008 Am avut acest defect si a disparut prin schimbarea condensatorilor din sursa,din secundar(pe +B in special),a fost un tv destul de fiabil dupa parerea mea. Link to comment Share on other sites More sharing options...
qazaq Posted January 24, 2008 Author Share Posted January 24, 2008 Buna tuturor!In primul rind vreau sa va multumesc de ajutor,prin ideile care mi le-ati dat,mai ales lui tv1 si lui Nonny 149 pt.ca ei au fost cei mai apropiati de idee.Problema am rezolvat-o prin inlocuirea condensatorului C206=22nF/1KV de pe placa TK. eu am mai scos condensatorul asta de pe placa si l-am masurat cu instrumentul de masura ,mi s-a parut ok ca ma asteptam sa aiba rezistenta,dar nu a avut chiar din contra este intrerupt,si nu am avut la indemina unu de valoarea asta,dar astazi l-am inlocuit cu unul de 10nF/1,5KV si merge brici.Tensiunea pe G2 s-a facut 400-450v.este ok.Va multumesc inca odata de ajutorul acordat (care cu ce a putut)!Numai bine! :yawinkle: :smt039 Link to comment Share on other sites More sharing options...
Archived
