Guest jon Posted January 21, 2008 Share Posted January 21, 2008 cum se poate remedia problema care produce deformarea imaginii? Quote Link to comment Share on other sites More sharing options...
paun nelu Posted January 21, 2008 Share Posted January 21, 2008 c de 100 uf/400 schimba-l si totodata verifica tens.u1 Quote Link to comment Share on other sites More sharing options...
Mihai85 Posted January 21, 2008 Share Posted January 21, 2008 Parca am mai vazut defectul asta si era din cadre, C-uri uscate sau CI. Quote Link to comment Share on other sites More sharing options...
Guest jon Posted January 24, 2008 Share Posted January 24, 2008 am schimbat c-ul de 120uF/400V cu unul de 100uF/400v si nu s-a rezolvat. Ce anume ar mai fi de schimbat? Quote Link to comment Share on other sites More sharing options...
Nonny149 Posted January 24, 2008 Share Posted January 24, 2008 verifica C806S-C807S,masoara tensiunile scoase de sursa.dupa cum se vede in poza are brum cu frecventza joasa.inlocuieste condensatorii din primarul sursei de alimentare. Quote Link to comment Share on other sites More sharing options...
gheo23 Posted January 24, 2008 Share Posted January 24, 2008 CKT 2190 e cu tda 1170n.E posibil sa fie, dar, din imagine parca ar fi c-ul de filtraj al alim cadrelor.Dar mai incearca si ceilalti cond din cadre.Imag pe care ai prez induce in error!Parca ar fi facuta cu un Smena.De curiozitate, cu ce tel e facuta? Quote Link to comment Share on other sites More sharing options...
Mihai85 Posted January 24, 2008 Share Posted January 24, 2008 Daca te hotarasti sa schimbi tda 1170N sa nu pui altul cu alta terminatie de ex cu S (ca la tv alb-negru) ca o sa ai dim redusa si eventual o intoarcere in partea de sus(am patit asta) si vezi de unde cumperi ca sunt si facaturi.Mai bine din recuperari.Din cate stiu eu pe acest sasiu se foloseste tda 1170H.Bafta. Quote Link to comment Share on other sites More sharing options...
tv1 Posted January 24, 2008 Share Posted January 24, 2008 Daca vrei sa nu ai probleme cativa ani cu acest sasiu schimbi condensatorii urmatori:C801=C807=10mF;;C805=100mF;C815=1mF din primarul sursei de alimentareC804=1000mF;C805=100mF;C806=C807=47mF/160V din secundar sursaC302=C423=100mF;C303=4,7mF;C305=470mF baleiaj vertical C431=4,7 sau 10mF/250V filtraj tensiune alimentare etaj final videoTDA1170N nu face acest defect.(este provocat de un filtraj,in principiu cele de pe B+ sau alimentare cadre) Quote Link to comment Share on other sites More sharing options...
Guest jon Posted February 6, 2008 Share Posted February 6, 2008 ieri am schimbat toti condensatorii indicati, parca se vede mai bine insa pe fond alb se vad dungi negre subtiri si dese de la jumatate in jos. S-a mai lovit cineva de aceasta problema?PS. poza n-a iesit bine nu din cauza aparatului ci din cauza semnalului prost de la antena Quote Link to comment Share on other sites More sharing options...
mircea626 Posted February 8, 2008 Share Posted February 8, 2008 posibil sa ai integratu de cadre defect Quote Link to comment Share on other sites More sharing options...
baza Posted February 8, 2008 Share Posted February 8, 2008 cit e tensiunea de alimentare a 1170? e corecta?ce amplit. v-v ai p bobina deflexie cadre?cat e amplit. pe rez. inseriata cu bobina, de pe care se culege tens de reactie?ia fa niste poze cu oscilogramele si pune-le pe forum.baza Quote Link to comment Share on other sites More sharing options...
Guest jon Posted February 11, 2008 Share Posted February 11, 2008 asta-i imagine tv-ului meu dupa ce am schimbat condensatorii, e mai buna decat inainte dar tot mai apar dungi negre de la jumate in jos.Am masurat tensiunea de alimentare a 1170 si e corecta.Nu am osciloscop. Se poate verifica prin alta metoda? Quote Link to comment Share on other sites More sharing options...
Nonny149 Posted February 11, 2008 Share Posted February 11, 2008 asta-i imagine tv-ului meu dupa ce am schimbat condensatorii, e mai buna decat inainte dar tot mai apar dungi negre de la jumate in jos.Am masurat tensiunea de alimentare a 1170 si e corecta.Nu am osciloscop. Se poate verifica prin alta metoda?incearca cu alt circuit integrat. Quote Link to comment Share on other sites More sharing options...
gheo23 Posted February 14, 2008 Share Posted February 14, 2008 Ai rez? De curiozitate, a fost tda def/Cnd am intrebat cu ce ap foto a fost facuta poza ma gandeam ca ap foto vechi aveau timp de exp mare si apareau acele dungi caracteristice-pauza dintre 2 cadre succesive. Quote Link to comment Share on other sites More sharing options...
Guest jon Posted February 15, 2008 Share Posted February 15, 2008 nu am rezolvat problema, habar nu am de unde e, totusi cred ca nu e defect tda sau alt integrat, astea ori merg ori nu merg. Intrebarea care ar trebui sa duca la rezolvarea problemei este : Care bloc functional produce problema? (dungi negre orizontale subtiri si dese de la jumatatea imaginii in jos) Quote Link to comment Share on other sites More sharing options...
Join the conversation
