Guest tornado220 Posted January 19, 2008 Share Posted January 19, 2008 am nevoie de o schema de amplificator de 2x150w relativ simpla cu integrate sau tranzistoare care sa mearga la +/- 35Vmultumesc anticipat. Quote Link to comment Share on other sites More sharing options...
cipa_maria Posted January 19, 2008 Share Posted January 19, 2008 e buna? Quote Link to comment Share on other sites More sharing options...
Dr.L Posted January 20, 2008 Share Posted January 20, 2008 150w la +/-30v e cam imaginartrebuie peste +/-50v,asta pe 4 ohmi Quote Link to comment Share on other sites More sharing options...
zal Posted January 20, 2008 Share Posted January 20, 2008 Doar daca face un amplif in punte la tensiunea aia :yawinkle: . Quote Link to comment Share on other sites More sharing options...
mircea888 Posted January 20, 2008 Share Posted January 20, 2008 pai poti sa faci 4 amplificatoare ca ala propus si le pui 2 cate 2 in punte cu niste defazoare,e destul de complicat, mai bine cauti alt traf si folosesti tot schema de mai sus dar cu mai multi finali si la o tensiune de alimentare mai mare.ai putea apela la TDA7294, 2 bucati in punte se apropie de 150w/8ohmipana la urma pe ce impedanta vrei sa mearga acest amplificator? Quote Link to comment Share on other sites More sharing options...
Guest tornado220 Posted January 20, 2008 Share Posted January 20, 2008 am un traf de 35V si nu vreau neaparat 150W... amplificatorul il folosesc la niste boxe no namem-am apucat de amplificatorul propus aseara si voi face si cu TDA 7294 Quote Link to comment Share on other sites More sharing options...
Guest tornado220 Posted January 20, 2008 Share Posted January 20, 2008 cu tranzistori B 688 si D 718 ce se poate face? Quote Link to comment Share on other sites More sharing options...
mircea888 Posted January 20, 2008 Share Posted January 20, 2008 cu tranzistori B 688 si D 718 ce se poate face?depinde cati ai, cu o pereche poti face un amplificator cam de 50w. la o tensiune de alimentare de +/-35VDC un amplificator ar debita cam 70w/4ohmi, daca folosesti finalii astia ar fi bine sa pui amplificatorul pe boxe de 8ohmi. Quote Link to comment Share on other sites More sharing options...
Guest tornado220 Posted January 20, 2008 Share Posted January 20, 2008 am cate 6 de fiecare va rog sa ma ajutati cu o schema pentru tranzistorii mei. Quote Link to comment Share on other sites More sharing options...
zal Posted January 20, 2008 Share Posted January 20, 2008 Alege orice schema cu tensiunea de alimentare asemanatoare, posteaz-o sau da o legatura sa o vedem si facem analize dupa aia. Nu exista scheme speciale ptr un anume tip de trz, se pot folosi orice trz cu anumite conditii. Quote Link to comment Share on other sites More sharing options...
yogi72cj Posted January 28, 2008 Share Posted January 28, 2008 am eu schema ideala pt tine aici: viewtopic.php?f=5&t=12015 poti sa pui in loc de bd tranzistorii tai,4 bucati pe canal daca te intereseaza am si cablaj de vanzare,am comandat mai demult citeva zeci de bucati si am folosit putine si schema cu nmos postata la inceputul topicului este inspirata 95% din schema pusa de mine Quote Link to comment Share on other sites More sharing options...
Guest Ky_Cristian Posted July 13, 2008 Share Posted July 13, 2008 Am vazut ca s-a vorbit mai sus de tda 7294. Am un traf de 2X 24V, tensiune asimetrica, intensitate 5A: se poate folosi pentru tda 7294? Sau stiti voi un integrat mai bun? As vrea sa obtin cam 100W pe 8 ohmi, chiar daca integratele trebuie puse in punte. In caz ca nu prea se gaseste nimic, as fi dispus sa incerc si ceva pe tranzistori, doar sa nu fie prea complicat. Multumesc Quote Link to comment Share on other sites More sharing options...
zal Posted July 13, 2008 Share Posted July 13, 2008 Asta inseamna +/-35V redresat, merge pe dif de 8 Ohmi sa faci cu 2xTDA7294, insa nu au viata lunga, cel putin astea de acum, daca ai originale sau unele cumparate acum 7 ani, poti sa te apuci de treaba, vezi in datele c.i. schema. Quote Link to comment Share on other sites More sharing options...
Guest Ky_Cristian Posted July 14, 2008 Share Posted July 14, 2008 Merci de raspuns Zal, dar nu le am nici originale, nici cumparate acum 7 ani. De fapt, nu le am deloc. Vroiam sa le cumpar si sa realizez ampliful, dar daca zici ca nu se merita, atunci o sa ma orientez catre altceva. Totusi, crezi ca vor tine macar pana la revelion daca nu le folosesc la maxim (imi va fi foooooarte greu) si le pun o racire uriasa? Daca nu, ma poate ajuta cineva totusi, cu un alt integrat, asemanator cu 7294, ceva mai fiabil, alimentat tot cam intre 30-35V asimetric?Nu prea am experienta in ale electronicii sa stiu catre ce sa ma orientez si sa caut prin datasheet-uri, dar amplifurile cu integrate sunt destul de usor de realizat, si de aceea apelez la ajutorul vostru. Quote Link to comment Share on other sites More sharing options...
zal Posted July 14, 2008 Share Posted July 14, 2008 Pot sa-ti dau exemplul cu Logitech Z5500, unde la +/-33V, canalul de sub e cu 2x7294 in punte cu dif de 8Ohmi si de care nu am fost deloc impresionat. Mai bine cauti alt traf cum ti-au mai zis si altii si faci un amplif cu trz, rezista mai bine decit c.i. alea mici, oricita racire le-ai pune. Quote Link to comment Share on other sites More sharing options...
Join the conversation
