Kytan666 Posted January 16, 2008 Share Posted January 16, 2008 au ajuns la mine 2 dvd playere unul blue tech si unul seitechpartea mecanica e la fel la amandoua , placa de baza aprox la fel , sursele la fel , si ca asemanarea sa fie completa acelasi defect : nu invart discul, invart suportul gol dar nu au putere sa invarta cu tot cu discam alim motoarele cu 4.8, merg bine , am masurat pe mufa ce iese din placa si cu motorul conectat am 0.3-0.5V in momentul de spin prima oara cand intampin defectul ... are cineva o sugestie ? Quote Link to comment Share on other sites More sharing options...
Sorin Schiriac Posted January 17, 2008 Share Posted January 17, 2008 se rezolva cu spray de contact,bagi sprai prin orificiile din spatele motorului. Quote Link to comment Share on other sites More sharing options...
cristiansen Posted January 17, 2008 Share Posted January 17, 2008 vezi daca se incalzeste ic ce comanda motorul daca nu ic def daca da motor sau angrenaj def Quote Link to comment Share on other sites More sharing options...
Kytan666 Posted January 17, 2008 Author Share Posted January 17, 2008 IC-u e putin cald , in limite normale zic eu , pe motor scrie 5.9V eu i-am dat 4.8 si merge , angrenaj nu este fiind motorul de spin .. cu motorul conectat pe borne la motor am 0,3-0,5V cand invarte, fara disc invarte dar slab , cand am pus si disc nu mai invarte ... Quote Link to comment Share on other sites More sharing options...
cristiansen Posted January 18, 2008 Share Posted January 18, 2008 daca angrenajul laserului [de focalizare]nu misca nu por. motorul Quote Link to comment Share on other sites More sharing options...
Kytan666 Posted January 18, 2008 Author Share Posted January 18, 2008 laserul se aprinde , angrenajul misca corect , si lentila focalizeaza ..., problema e cu motorul de spin Quote Link to comment Share on other sites More sharing options...
cristiansen Posted January 21, 2008 Share Posted January 21, 2008 ic defect. Quote Link to comment Share on other sites More sharing options...
Sorin Schiriac Posted January 21, 2008 Share Posted January 21, 2008 nu ai nici un circuit defect,poate fii sursa defecta nu debiteaza curent sau motoarele blocate ,ti-am scris mai sus cum se procedeaza. Quote Link to comment Share on other sites More sharing options...
cristiansen Posted January 22, 2008 Share Posted January 22, 2008 verifica tensiunea pe ic cand bagi discul si iti faci o idee despre def. posibil sa fie alimentarea eu am intalnit numai driver def. Quote Link to comment Share on other sites More sharing options...
Kytan666 Posted January 28, 2008 Author Share Posted January 28, 2008 integratul are 4 iesiri .. pe toate in sarcina este tensiune .. pe cea de motor nu este .. , tensiunile din sursa sunt corecte si stabile insarcina de unde scot driver nush .. D5954 .... Quote Link to comment Share on other sites More sharing options...
ion_vasile Posted January 28, 2008 Share Posted January 28, 2008 Rezistenta de contact mare intre perii si colector.Schimba motorul . Quote Link to comment Share on other sites More sharing options...
johnny79 Posted February 2, 2008 Share Posted February 2, 2008 Masoara motorul pe ohmetru.In mod normal trebuie sa ai intre 8 si 10 ohmi,orice alta valoare mai mare sau mai mica implica scimbarea motorului.O solutie empiririca(imi era lene sa tot schimb motoare),cu o sarma subtire ,prin gaurile din capacul motorului in asa fel incat sa atinga contactele rotorului si alimentam motorul cu o tens de 5V.Asa reuseam sa i-l curat de oxizi.Spor la depanat. :smt024 Quote Link to comment Share on other sites More sharing options...
Guest Posted February 3, 2008 Share Posted February 3, 2008 Omul vorbeste despre motorul care invarte DVD-ul. Pana acum nu am vazut sa fie altfel decat motor pas cu pas si direct drive. Nu are perii. Nu are roti dintate sau pinioane. Nu are ce sa se strice la un astfel de motor. Se arde driverul care il comanda.In ce aparat ati vazut voi motor cu perii care invarte DVD-ul? Quote Link to comment Share on other sites More sharing options...
Depanatoru Posted February 3, 2008 Share Posted February 3, 2008 :weedman: La toate DVD Playerele de pe piata ( poate or mai fi si exceptii ). Mai demult se foloseau motoare pas cu pas in aparatele de firma. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 3, 2008 Share Posted February 3, 2008 "Cand toata lumea iti spune ca esti beat, mai bine te duci si te culci!" Nu sunt depanator iar DVD din astea de 1 milion playerul nu am vazut niciunul desfacut. Desi mi se pare tare ciudat :rolleyes: va cred pe cuvant. Quote Link to comment Share on other sites More sharing options...
Join the conversation
