Jump to content
dezmembrari audio
fluffy37
 Share
Comanda minima 30 lei, rezervari pana la 1 septembrie. Expediere doar prin posta sistem ramburs sau predare personala.
final yamaha 6 canale
1. carcasa cu ventilator si comutator pornire incluse 50 lei
https://ibb.co/mtqsGSW
https://ibb.co/30gzh7D
2. radiator aluminiu 20 lei
https://ibb.co/jhhRw3Q
https://ibb.co/FhBwCG1
3. tranzistori finali 2sd/2sb 20 lei perechea, 2sc/2sa 25 lei perechea
https://ibb.co/2hyqzRD
4. tranzistori prefinali 10 lei perechea
https://ibb.co/W3dT576
5. diode de putere 5 lei toate
https://ibb.co/HPbNrqN
6. 2sa1371/2sc3468 5 lei perechea
https://ibb.co/fD9FCdy
7. module intrari 15 lei bucata
https://ibb.co/NLCq9Rm
https://ibb.co/2YSbDYy
8. module cu borne difuzoare 5 lei bucata
https://ibb.co/PZsPvxF
9. tot ce se vede in poza 15 lei
https://ibb.co/h1sZSPV
10. modul redresare 35 lei
https://ibb.co/8s4VQ30
https://ibb.co/4Sb9S8b
11. placa etaj final 10 lei
https://ibb.co/4N48czc
12. traf alimentare 2x50v 100 lei
https://ibb.co/yXjR9Sk
diverse
13. doza philips fara ac 25 lei
https://ibb.co/Wpt3Cky
14. doza shure m75d cu ac pare ok, 75 lei
https://ibb.co/p2mMkRw
https://ibb.co/3fR6G0C
15. vumetre cu ace bune 20 lei perechea
https://ibb.co/51WNQCd
https://ibb.co/89qbDML
16. pungulita cu suruburi din amplifuri 10 lei
https://ibb.co/SVL07T0
17. filtraje 10 lei perechea
https://ibb.co/TK2Mb2s
18. traf onkyo 30 lei
https://ibb.co/cCMV7Hv
19. radiator tip tunel 20 lei
https://ibb.co/1X859ht
https://ibb.co/VMzvSc3
20. modul stabilizare 10 lei
https://ibb.co/5T9H9SN
21. 2 etaje finale functionale 50 lei fiecare
https://ibb.co/L82ynqL
https://ibb.co/g4by1ZZ
https://ibb.co/k6hWs87
22. modul redresare 15 lei
https://ibb.co/KyTkqjJ
23. radiator cu 2 perechi de bd313/314 bune 50 lei
https://ibb.co/y8m2wKM
https://ibb.co/F4J1jQw
si mai urmeaza
Link to comment
Share on other sites
  • Replies 149
  • Created
  • Last Reply
Top Posters In This Topic
3. tranzistori finali 2sd/2sb 20 lei perechea, 2sc/2sa 25 lei perechea----diponibile 4 perechi (2 si 2)
4. tranzistori prefinali 10 lei perechea-----(fara 4 perechi)
6. 2sa1371/2sc3468 5 lei perechea---- (fara 4 perechi)
diverse
15. vumetre cu ace bune 20 lei perechea-----valabile cele din stanga
continuam
amplificator de linie
24. carcasa cu ventilator 30 lei
https://ibb.co/qdDw36H
https://ibb.co/17zxS5j
25. traf toroidal 50 lei
https://ibb.co/LdgDhWz
26. placa completa etaj final cu finali pnp 60 lei
https://ibb.co/prvCfbM
https://ibb.co/6Rsm2mg
27. modul relee si comutatoare cu 6 pozitii 25 lei
https://ibb.co/KNCMkBN
28. placa frontala corectoare ton si volume 20 lei
https://ibb.co/Hrpp9WG
29. modul intrari cu 12 operationale 30 lei
https://ibb.co/PzgPwHs
30. modul redresare si stabilizare pe 24v 25 lei
https://ibb.co/YNyRTSj
https://ibb.co/MPfDbF5
31. traf iesire 25 lei, lot butoane 10 lei
https://ibb.co/tJjBc8n
diverse
32. finali 2sc4467/2sa1694 15 lei, 2sc5197/2sa1940 15 lei perechea, contoare banda deck 5 lei ambele
https://ibb.co/J2ZVg1f
33. vumetre cu ace 20 lei perechea
https://ibb.co/xqMFFyN
https://ibb.co/WBqD4yQ
34. vumetru cu leduri 15 lei
https://ibb.co/nsKmLXN
35. pungulita cu suruburi din amplifuri 10 lei
https://ibb.co/Q7W8qDQ
36. 2 perechi mufe tata/mama cu multi pini 5 lei perechea
https://ibb.co/7ph63VJ
37. tot ce se vede in fiecare poza 15 lei
https://ibb.co/Z8KrNv0
https://ibb.co/rkg7j3b
38. ventilatoare 5 lei bucata
https://ibb.co/HCxZP27
https://ibb.co/KjYvwpr
39. picioruse aparate 5 lei setul
https://ibb.co/FYtQzjK
40. inele ferita 5 lei toate
https://ibb.co/NZ2jjhs
41. placa mare grundig cu etaje finale 50 lei
https://ibb.co/MP1S4F6
42. tot ce se vede in poza 20 lei
https://ibb.co/PtgzC1H
43. modul deck 15 lei
https://ibb.co/Fbb5M45
44. modul mare radio complet combina grundig 80 lei
https://ibb.co/QJdn9yk
https://ibb.co/ZSL2ZXc
https://ibb.co/myV02BG
45. etaj final cu 8 finali complet 100 lei
https://ibb.co/WDLctR9
https://ibb.co/Sx0hTZf
46. placa radio 30 lei
https://ibb.co/3MTzKMx
47. etaj final cu bd-uri 40 lei
https://ibb.co/pfvmL5w
https://ibb.co/mvGsGJ9
48. corector ton 15 lei, modul deck 10 lei
https://ibb.co/pzD4S7F
49. selector posturi fixe 15 lei
https://ibb.co/VYC344V
50. tot ce se vede in fiecare poza 15 lei
https://ibb.co/FVgt9wv
https://ibb.co/93KrwTM
51. placa radio 30 lei
https://ibb.co/R72QV2G
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
  • Create New...
Important Information
