mirceaioan Posted January 5, 2008 Share Posted January 5, 2008 Am un DVD DAEWOO DHC-X150 care are defecta placa de comanda (pe ea se gaseste procesorul,legatura cu lentila optica si celelalte legaturi la mecanica si alimentare. Va rog daca are cineva aceasta placa Procesor Vibrato ES6698FDF. Va multumesc. Quote Link to comment Share on other sites More sharing options...
Join the conversation
