diddygy Posted January 15, 2023 Share Posted January 15, 2023 (edited) Salut detin acest laptop Acer TravelMate B si vreau sa pun pe el Windows 7 UEFI Cind intru in BIOS nu pot schimba Boot Mode: UEFI pur si simplu nul pot accesa Am incercat cu diferinte versiuni de Windows 7 cu UEFI incerc sa intstalez Windows dupa repornire primesc o erroare tin sa mentionez pot instala windows 8 sau 10 fara probleme Am pe laptop hard disk SSD m.2 SATA Nvme Am incercat sa instalez pe alt laptop Acer E5-511 cu hard disk normal si primesc aceasi erroare dupa ce copiaza fiesierele de windows si da restart primesc aceasi erroare . Cineva care sa mai confruntat cu asa ceva ? Edited January 15, 2023 by diddygy Link to comment
validae Posted January 15, 2023 Share Posted January 15, 2023 https://www.google.com/search?q=how+to+disable+uefi+on+laptop&sxsrf=AJOqlzVzHqWyn9gBr0K9XEiEM1vwwDypgA%3A1673788146167&source=hp&ei=8vrDY_7RB_KgiLMPzZi3wAo&iflsig=AK50M_UAAAAAY8QJAv46ITTrHe2xvxYFTvL2cvNN61Xe&oq=&gs_lcp=Cgdnd3Mtd2l6EAEYATIHCCMQ6gIQJzIHCCMQ6gIQJzIHCCMQ6gIQJzIHCCMQ6gIQJzIHCCMQ6gIQJzIHCCMQ6gIQJ1AAWABgxw5oAXAAeACAAQCIAQCSAQCYAQCwAQY&sclient=gws-wiz Link to comment
diddygy Posted January 15, 2023 Author Share Posted January 15, 2023 Multumesc pentru raspuns rapid problema la mine nu e de dissable SECURE BOOT daca va uitati la poza o sa vedeti ca e pe Disabled ! Ma confrunt cu intrarea in BOOT MODE UEFI nul pot acesa sal pun pe LEGACY. Am facut windows 7 64 bit cu RUFUS booteaza intru la partitie copy Windows si dupa restart ma contrunt cu imaginea pe fond negru . Am incercat mai multe versiuni de Windows 7 64BIT cu UEFI dar ceva nu e bine dupa restart sa continue instalare mai departe... Link to comment
validae Posted January 15, 2023 Share Posted January 15, 2023 Tot din BIOS se face schimbarea: Power on system. Press F2 when prompted to enter BIOS menu. Navigate to Boot Maintenance Manager -> Advanced Boot Options -> Boot Mode. Select the desired mode: UEFI or Legacy. Link to comment
sorintv Posted January 15, 2023 Share Posted January 15, 2023 (edited) Eu am patit tot la un Acer la care vroiam sa instalez Win 10, si problema era din setarile Rufus. NTSF, si, MBR cu UEFI sau GPT cu UEFI, pentru a putea boota. Edited January 15, 2023 by sorintv Link to comment
diddygy Posted January 16, 2023 Author Share Posted January 16, 2023 Acum 21 ore, validae a spus: Tot din BIOS se face schimbarea: Power on system. Press F2 when prompted to enter BIOS menu. Navigate to Boot Maintenance Manager -> Advanced Boot Options -> Boot Mode. Select the desired mode: UEFI or Legacy. Nu exista asa ceva decit Boot Mode UEFI care nu poate fi acesat de nici un fel ,am facut si update de Bios si nimic Link to comment
modoran Posted January 16, 2023 Share Posted January 16, 2023 Daca ai disc nvme ala oricum e obligatoriu sa fie accesat via GPT si UEFI si tot ce trebuie. Baga windows 10 mai bine. Link to comment
diddygy Posted January 16, 2023 Author Share Posted January 16, 2023 Am pe el instalat Windows 10 ea toate drivere singur ,faza e ca as fi vrut sai pun Windows 7 Link to comment
nel65 Posted February 14, 2023 Share Posted February 14, 2023 O fi hardul formatat GPT si la Rufus cand ai facut stickul ,ai selectat MBR ? Sau invers? Trebuie "potrivite" identic ! De studiat... Link to comment
