cimitavita Posted September 17, 2022 Share Posted September 17, 2022 (edited) încearcă cu leduri IR. Am niște leduri IR de la niște repartitoare pe care cad 1,49V la 50 mA. Edited September 17, 2022 by cimitavita Quote Link to comment Share on other sites More sharing options...
florinapostol Posted September 17, 2022 Author Share Posted September 17, 2022 Va multumesc pentru raspunsuri! Saptamana viitoare imi vin restul de piese si ma apuc de treaba. cred ca final va fi montajul cu LM 317. Quote Link to comment Share on other sites More sharing options...
Marele Savant Posted September 17, 2022 Share Posted September 17, 2022 Acum 6 ore, misuraelectronic a spus: daca inseriezi 2 diode redresoare banale , polarizate direct , vei obtine 1,2 volti , nu 1,4 volti ...la carte spune extrem de clar ...0,6volti siliciul si 0,2 volti germaniul ... dupa alte carti si usor verificabil practic, pot fi gasite usor diode care in conductie directa au peste 0,7V! si oricum tensiunea difera si in functie de curentul prin dioda! nu scrie in nici o carte ca valoarea respectiva este batuta in cuie! Quote Link to comment Share on other sites More sharing options...
sesebe Posted September 17, 2022 Share Posted September 17, 2022 (edited) Încearcă doua diode zener in conductive directa. De obicei pe zenere măsuram in conductie directa puțin peste 0 7V. Din ce montaj este dioda necesara? Nu cred ca poți utiliza acolo un montaj cu 317 setat pe 1.5V, pericol de oscilații. Edited September 17, 2022 by sesebe Quote Link to comment Share on other sites More sharing options...
Marele Savant Posted September 18, 2022 Share Posted September 18, 2022 TL431? Quote Link to comment Share on other sites More sharing options...
ignotus52 Posted September 18, 2022 Share Posted September 18, 2022 In fragmentul de schema postat este vorba de un generator de currnt de cca 20 mA. Ar fi util un fragment mai mare de schema, din care sa rezulte tensiunea de intrare si sarcina. Quote Link to comment Share on other sites More sharing options...
grosu99 Posted September 18, 2022 Share Posted September 18, 2022 Pune 2 diode 4007 in serie ! ce tot le bibiliti atat ?! Quote Link to comment Share on other sites More sharing options...
florinapostol Posted September 18, 2022 Author Share Posted September 18, 2022 Acum 49 minute, ignotus52 a spus: In fragmentul de schema postat este vorba de un generator de currnt de cca 20 mA. Ar fi util un fragment mai mare de schema, din care sa rezulte tensiunea de intrare si sarcina. Acum 27 minute, grosu99 a spus: Pune 2 diode 4007 in serie ! ce tot le bibiliti atat ?! o simulare cu potentiometrul facut din 2 rezistente. minim si maxim Quote Link to comment Share on other sites More sharing options...
cimitavita Posted September 18, 2022 Share Posted September 18, 2022 TL431 are referința 2,56V. TLV431 are referința 1,25V și îl poate face de 1,5V cu 2 rezistențe. Dar trebuie să pună și 1 sau 2 condensatoare pentru a evita oscilațiile. Problema apare dacă schema nu permite condensatoarele... Quote Link to comment Share on other sites More sharing options...
ignotus52 Posted September 18, 2022 Share Posted September 18, 2022 De fapt deci este vorba de o sursa de tensiune 0 - 60 v cu limitare de curent. Daca nu deranjeaza un ecart al curentului de limitare de 3-4 mA ,dat de dispersia diodelor si de variatiile de temperatura, puneti doua diode 1N4148 sau ceva asemanator,curentul maxim prin ele este sub 10 ma,limitat de R2,R10,R11 . Quote Link to comment Share on other sites More sharing options...
grosu99 Posted September 18, 2022 Share Posted September 18, 2022 E un limitator de curent ...se tatoneaza rezistenta R12 Quote Link to comment Share on other sites More sharing options...
BRANCA Posted September 18, 2022 Share Posted September 18, 2022 (edited) Grosu99 are dreptate,e vorba de o limitare de curent la 20 mA."Clasic" se făcea cu două diode inseriate... Dacă e de "farmacie" la curentul max livrat se tatonează diodele şi R12. https://electronics.stackexchange.com/questions/39465/current-limiters-using-transistors-and-diodes Edited September 18, 2022 by BRANCA Quote Link to comment Share on other sites More sharing options...
Marian Posted September 18, 2022 Share Posted September 18, 2022 Topicul asta este confirmarea zicalei "a nu vedea padurea din cauza copacilor", si arata ca suntem electronisti dar nu cunoastem electronica nici cat echivalentul a 2 plus 2. 20 hours ago, misuraelectronic said: la carte spune extrem de clar ...0,6volti siliciul si 0,2 volti germaniul De la caderea tipica pe jonctiunea de siliciu si pana la caracteristica directa a unei anumite diode e cale cam de la pamant la Jupiter ( aproape si totusi de neatins ). Iata ce zice Vishay despre banala 1N4007: Intre 10mA si 100mA sunt mai bine de 100mV diferenta, si pana la 1A sunt probabil vreo 350mV diferenta. Diotect semiconductor confirma si dependenta de temperatura a caderii directe de pe dioda: Deci nu luam in calcul 0,6V decat daca am verificat un grafic care arata curentul si temperatura la care sunt valabili cei 0,6V. Altfel media tipica de folosit in calcule e 0,65-0,7 si se verifica apoi practic. 20 hours ago, misuraelectronic said: daca vrei sa faci doar teste ...ia o baterie R3 sau R6 Daca prima para cand ati sugerat bateria ar fi fost scuzabil devreme ce nu cunosteati circuitul, in schimb ce am citat eu aici a fost postat dupa ce schema a fost pusa de OP: 20 hours ago, florinapostol said: Ce D-zeu facem cu bateria aici??? Pai dvs sunteti cei care amendati dur greselile altora si nu vedeti ca-i vorba de o nenorocita de sursa de curent constant? Dar voi ceilalti ce scuza aveti??? Acolo in schema nu se stabilizeaza o anumita tensiune ci un curent, dioda nici macar nu-i folosita ca zener ci ca dioda normala, si sunt 2 diode, ca asa e normal la un astfel de circuit ( tensiunea zener de 1,5V e irelevanta, uitati-va la polarizare ). Adica avem cea mai simpla forma de generator de curent constant cu tranzistor, cea cu 2 diode inseriate in baza, si merg acolo oricare 2 diode redresoare pe siliciu ( tranzistorul fiind pe siliciu ), de la 4148 pana la 4007. PS: Asa se intampla cand ne uitam la o schema dar nu o intelegem pentru ca teoria e irelevanta, conteaza experienta practica... PS2: Daca cineva se supara datorita postarii mele n-are decat, mi se pare jenant sa ne incurcam la o schema atat de banala. Quote Link to comment Share on other sites More sharing options...
grosu99 Posted September 18, 2022 Share Posted September 18, 2022 Daca consumi 5 mA e o sursa de tensiune si daca treci de 20 mA e sursa cu limitare ... Quote Link to comment Share on other sites More sharing options...
Marian Posted September 18, 2022 Share Posted September 18, 2022 Tensiune care e dictata de polarizarea din baza acelui BF, si schema nu o arata care e. Apoi oricum acea tensiune n-are nici o legatura cu zenerele alea. Quote Link to comment Share on other sites More sharing options...
Join the conversation
