GOLOGAN Posted June 9, 2022 Share Posted June 9, 2022 Main : 17MB211S Sursa : 17IPS62 Ecran : VES315WNDL-2D-N23. TC : RC49141 Va salut ! Tv-ul se restarteaza in bucla. Dupa cateva incercari de resoftare nereusite apelez la dvs pentru un soft. Multumesc. Quote Link to comment Share on other sites More sharing options...
GOLOGAN Posted June 9, 2022 Author Share Posted June 9, 2022 Acum 2 ore, GOLOGAN a spus: Main : 17MB211S Sursa : 17IPS62 Ecran : VES315WNDL-2D-N23. TC : RC49141 Va salut ! Tv-ul se restarteaza in bucla. Dupa cateva incercari de resoftare nereusite apelez la dvs pentru un soft. Multumesc. Rezolvat . Multumesc d-lui Tavi. Quote Link to comment Share on other sites More sharing options...
YO5VAE Posted February 5 Share Posted February 5 Buna seara. Oare mai aveti pe undeva firmware-ul pt. usb? Am tot rescris flash-ul, dar se comporta la fel ca inainte. Multumesc! Quote Link to comment Share on other sites More sharing options...
iuliantv Posted February 5 Share Posted February 5 Acum 22 minute, YO5VAE a spus: Buna seara. Oare mai aveti pe undeva firmware-ul pt. usb? Am tot rescris flash-ul, dar se comporta la fel ca inainte. Multumesc! la fel ca inainte? nu vad nimic postat de dv,doar daca folositi clone Quote Link to comment Share on other sites More sharing options...
YO5VAE Posted February 5 Share Posted February 5 Acum 2 minute, iuliantv a spus: la fel ca inainte? nu vad nimic postat de dv,doar daca folositi clone Scrie corect flash-ul. Chiar si dupa ce testez tv-ul, daca citesc flash-ul, e ultimul dump urcat. Pare ca nu comunica flashul cu restul. Tensiunile sunt corecte. Quote Link to comment Share on other sites More sharing options...
iuliantv Posted February 5 Share Posted February 5 vorbesc degeaba ,nu are rost sa mai continui Quote Link to comment Share on other sites More sharing options...
YO5VAE Posted February 5 Share Posted February 5 Poate sunt eu prea prost. Imi cer scuze daca v-am deranjat. Sau poate nu v-ati exprimat dvs destul de coerent sa inteleg ce informatii doriti. Quote Link to comment Share on other sites More sharing options...
iuliantv Posted February 5 Share Posted February 5 (edited) Acum 14 minute, YO5VAE a spus: Poate sunt eu prea prost. Imi cer scuze daca v-am deranjat. Sau poate nu v-ati exprimat dvs destul de coerent sa inteleg ce informatii doriti. nu domnule dv trebuie sa oferiti cat mai multe informatii ,cånd vreti ajutor,nu sa ,,va traga de limbå,,cei ce vor sa va ajute si va citez ,, Buna seara. Oare mai aveti pe undeva firmware-ul pt. usb? Am tot rescris flash-ul, dar se comporta la fel ca inainte. Multumesc!,, nu vad nicaieri ce placa aveti in tv,ce display,sa nu mai spun si va citez din nou ,,se comporta la fel ca inainte.,, unde a.ti spus cum se comporta ,inainte sau acum? nicaieri a.ti spus ca a.ti scris flashul ,care flash ?ca sant 2 nand flash si spi flash astea merg doar pereche ,si daca rescrieti nand flashul ,adio NETFLIX si parca si CI+ o spun din propie experientå nu din carti sau discutii Edited February 5 by iuliantv Quote Link to comment Share on other sites More sharing options...
GeorgeS Posted February 5 Share Posted February 5 @YO5VAE, ai scris doar ca: "se comporta ca inainte", dar nimeni nu stie cum se comporta inainte. Colegul @iuliantv, asta te intreaba ... concret, cum se comporta? Quote Link to comment Share on other sites More sharing options...
YO5VAE Posted February 5 Share Posted February 5 (edited) Am aceleasi probleme ca si initiatorul topicului. Boot-loop. 7 flashuri la led la pornire. Logo-ul JVC se aprinde vreo 5 secunde, dupa care ramanea doar back-light-ul, iar dupa vreo 20-30 de secunde se restarta. Exact aceleasi componente pe care le avea si initiatorul topicului, tocmai de aceea am scris aici. MB: 17MB211S Panel: VES315WNDL-2D-N23 Flash: 25Q16 TV: JVC LT-32VH53i Am scris dump-uri doar in 25q16. Din pacate, intre timp, i-am dat un soft usb de Hitachi cu aceleasi componente, si se comporta aproape la fel. Acum apare logo-ul Hitachi cateva secunde, apoi ramane doar backlightul, si dupa vreo 20-30 de secunde se restarteaza. Diferenta e ca LED-ul palpaie continuu, nu se mai opreste dupa 7 flashuri. Si bineinteles, nu mai reactioneaza nici la telecomanda can incerc alt soft usb. PS. Dupa ce i-am dat dump-ul original (descarcat din el) in 25q16, merge din nou telecomanda, si pot din nou urca in el firmware usb. Edited February 5 by YO5VAE Quote Link to comment Share on other sites More sharing options...
iuliantv Posted February 5 Share Posted February 5 incercati cu asta https://easyupload.io/7lhmwo daca nu vrea ,rescrieti spi flash cu binul vechi,ce a fost initial in tv sper ca l.ati salvat si dupå reincercati cu usb cu softul de mai sus Quote Link to comment Share on other sites More sharing options...
YO5VAE Posted February 5 Share Posted February 5 (edited) Multumesc. Din pacate la asta, se restarteaza mult mai repede, la vreo 11 secunde. Back-light-ul se aprinde, nu afiseaza nimic, iar dupa vreo 11 secunde se restarteaza. Led-ul flash-uieste cam o data pe secunda. Si nu merge nici telecomanda sa bag iar flash-ul usb. Edited February 5 by YO5VAE Quote Link to comment Share on other sites More sharing options...
iuliantv Posted February 5 Share Posted February 5 (edited) se foloseste o telecomanda vestel dupå cate am inteles eu la 17mb211 sant 3 versiuni daca nu ai versiunea care trebuie nici nu merge,dar eu unul dupå mainboard nu am reusit sa ,,identific nimic,, doar in menu service apare deci daca gasiti vre.o poza a meniului service cu un tv ca al dv ar fi ceva ps a.ti rescris cu binul vechi? Edited February 5 by iuliantv Quote Link to comment Share on other sites More sharing options...
YO5VAE Posted February 5 Share Posted February 5 (edited) Acum 9 minute, iuliantv a spus: se foloseste o telecomanda vestel dupå cate am inteles eu la 17mb211 sant 3 versiuni daca nu ai versiunea care trebuie nici nu merge,dar eu unul dupå mainboard nu am reusit sa ,,identific nimic,, doar in menu service apare deci daca gasiti vre.o poza a meniului service cu un tv ca al dv ar fi ceva ps a.ti rescris cu binul vechi? Da, am rescris bin-ul vechi (original din 25q16), Daca nu il rescriu, nu mai pot face update via USB ca nu mai merge telecomanda. MB e 17MB211S, nu 211. Am incercat mai multe firmware-uri usb, inainte de fiecare cu rescriere SPI-Flash cu dump-ul original. Acum am doar back-light, fara logo, cu restart la vreo 10-15 secunde si cu led-ul la aprox. 1 secunda. Cand isi face update e mult mai rapid. Probabil o sa comand un MB, nu cred ca o sa resusesc sa il resuscitez pe asta. Multumesc. PS. Nu pot intra in menu-service, ca nu ajunge acolo. Edited February 5 by YO5VAE Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted February 5 Share Posted February 5 Scrie nandul cu programatoru, nu mai umblati aiuria cu stick Quote Link to comment Share on other sites More sharing options...
Join the conversation
