Jump to content
Vand aparat de masura digital cu autoscalare si conexiune USB! Bargraf! MS8250D Mastech
CADASEDA
NCV - masurare tensiune fara contact! 1000V cc si ac, rezistente 0,6Ω - 66MΩ, condensatori 6pF - 660µF, frecventa 0.6 Hz
- 66Mhz. software de windows. pret 250 lei.
tel 0723423784
DC Voltage 660mV +-(0.8%+3)
                6.6V/66V/660V/1000V +-(0.5%+5)
AC Voltage 660mV +-(1.5%+5)
                6.6V/66V +-(1.2%+5)
                660V/1000V +-(1.0%+3)
DC Current 660µA/6600µA/66mA/660mA +-(1.0%+5)
                10A +-(2.0%+5)
AC Current 660µA/6600µA/66mA/660mA +-(1.5%+5)
                10A +-(3.0%+5)
Resistance 660Ω/6.6/66/660KΩ/6.6MΩ +-(0.8%+5)
                66MΩ +-(1.5%+5)
Capacitance 6.6nF +-(4.0%+5)
                        66/660nF/6.6/66/660µF +-(3.0%+3)
                        6.6mF/66mF +-(4.0%+5)
Frequency 66Hz/660Hz/6.6kHz/66kHz/660kHz/6.6MHz/66MHz +-(1.5%+5)
Duty Cycle 0.1%~99.9% +-(2%+2)
Auto range and manual range.
Full range overload protection
Max. voltage between terminal and ground:
CAT IV, 600V DC or AC rms.
CAT III, 1000V DC or AC rms.
Operational altitude: 2000 m max.
Display: LCD
Displayed maximum value: 6599
Polarity Indication: Automatically display " - "
Over range indication: "OL " or "-OL"
Sampling rate: approx. 0.4s/analog bar graph: approx.0.04s except for current measurement: approx. 1s/bar graph: 0.1s
Unit display: functions and unit power
Auto power off time: approx.15 min.
Power Supply: 9V Battery
Low Battery Indication: displays shows '  '
Temperature coefficient: less than 0.1 x accuracy/℃
Operating temperature: 0℃ to 40℃
Storage temperature: -10℃ to 50℃
Dimension: 180x86x52mm
Weight: about 250g (without battery)
Order Ref. Number: MS8250DC15L
Display: 6600 counts
Auto Ranging
Manual Ranging
Auto Power Off
Relative Measurement
True Root Mean Square
Non-Contact Voltage Detection
Diode: 3.2V
Continuity Buzzer: <50Ω
MAX/MIN
Bar Graph
Data hold
Low Battery Display
Display Backlight
USB Interface: Windows OS
http://www.mastech-group.com/products.php?cate=123&PNo=142
Display 6600 counts
● Auto Ranging
● Manual Ranging
● Auto Power Off
● Relative Measurement
● True RMS
● Non-Contact Voltage Detector
● Diode Open voltage 3.2V
● Continuity Buzzer <50Ω
● MAX/MIN
● Bar Graph
● Data Hold
● Low Battery Display
● Display Backlight
● USB Interface Windows OS
Clipboard01.thumb.jpg.30eb2c6c1a16d728dea551953e43d1c6.jpgphoto_b_36_150364152116.thumb.jpg.523cea481d731391b79054483d954bf3.jpgphoto_l_150278008314.thumb.jpg.2d87bd95c2a89e810d26041754bdce2b.jpg
Link to comment
  • 4 weeks later...
  • Replies 3
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Guest
This topic is now closed to further replies.
  • Create New...
Important Information
