Jump to content
CADASEDA
Vand aparat foto digital profesional Canon 1200D, DSLR. CA NOU! IMPECABIL!, cu sau fara obiectiv.
pret 700 lei
tel 0723423784
CARACTERISTICI CANON EOS 1200D + EF-S
Calitatea imaginii
Senzor: Format senzor Crop (1.3x - 2x) 22.3 x 14.9 mm CMOS
Rezolutie Efectiva: Intre 18 si 20 MPx
Profil Culoare: 14 Biti
Format Fisiere: RAW, JPEG
Mod Filmare: Full HD
Inregistrare Audio: Da
Control focalizare
Tip Focalizare: AF cu 9 puncte , sensor CMOS
Mod Focalizare: AI Focus, One Shot, AI Servo
Control expunere Sensibilitate: Auto (100 - 6400) • ISO 100, ISO 200, ISO 400, ISO 800. ISO 1600, ISO 3200, ISO 6400, ISO
12800 (expandat)
Tip Obturator: Electro-mecanic focal
Viteze Obturator: 30 - 1/4000 sec
Mirror Lock-up: Da
Masurarea Expunerii: Multi Preponderent central Partial
Moduri Balans de Alb: AWB, Daylight, Shade, Cloudy, Tungsten, White Fluorescent light, Flash, Custom
Moduri Presetate: Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined (x3)
Display Vizor Optic: Pentamirror Acoperire: 95% Marire: 0.8x Diametru vizor: 21.00 mm Corectie dioptrie : de la - 2.5 to
+0.
DOF Preview: Da
Display LCD TFT LCD , 7.6 cm , 3inch
Performante Capacitate Rafala: 3 fps
Temporizator: 2 sau 10 sec
Blit
Blit Integrat: Da , Auto, Manual Flash On/off
Raza Efectiva Blit: 9.20 m ( la ISO 100)
Patina Blit Extern: Da, hotshoe
Control Blit Extern: E-TTL II cu bliturile Speedlite seria EX
Viteza Maxima de Sincronizare: 1/200
Memorie si alimentare Carduri de Memorie Compatibile: SD, SDHC, SDXC, EyeFi
Alimentare: Acumulator Li-ion LP-E10
Intrare / Iesire Interfata Computer: USB High-Speed 2.0
Capacitati Direct Print: DA, PictBridge
Iesire Video: Da
Caracteristici Fizice Tip Pachet: Kit
Continut pachet: Body Canon DSLR EOS 1200D
Obiectiv EF-S 18-55mm f/3.5-5.6 DC (fara stabilizare)
Dimensiuni: 130 x 100 x 78 mm
Altele: 434 g
Optica Multiplicator Distanta Focala: 1.6x
Obiectiv Montura Obiectiv: EF/EF-S
Distanta focala: 29-88
Plaja Diafragme: 6
Filet Filtru: 58mm
Distanta Minima de Focus: 0.25 m Raport Marire: 0,34 (la 55 mm)
Constructie: 11 elemente in 9 grupuri
Stabilizare Imagine: Fara stabilizare
Lungime: 70mm
Diametru: 68,5 mm
Greutate: 200 g705227-800-800.thumb.jpg.9f7f9a34d471d86b8705c6cf9d5038cd.jpg
Link to post
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
