Jump to content
Ovidanie
HP ProLiant DL370G6
M-am pricopsit cu un asemenea server, vreau sa stiu daca am sanse sa-l vand si daca da, cam cu cat?
y4mdeloxwpttueunRigEmGc6XjFDoU5tHse-4pN8
y4mPR_7M8by760Vg67V1SbZwaF_AQ31s3QormHKs
y4mgpO-eTG-gAlgjsgpi6d81P0hgIsESdBZ8Cmgk
y4maGPs_OOrzjoRGnVvfcWfYq-AjyoJ-I7QdGTvN
y4mIkbxZSBGU0_g3SfBvLoLwgFoPW4Cn_E7k8Wwb
Este varianta echipata cu un singur procesor.
6 bancuri de memorie, 3 de 4GB si 3 de 2GB
y4mn2vBS3Mn2iTTXLnxWRV-0eaVRtPMKFSyKu9IT
Link to post
Share on other sites
Trebuie sa spuneti configuratia completa, CPU, memorii(cantitate, tip[ECC Registered, ECC-UDIMM, etc], frecventa lor), placa de baza, nr. de HDD-uri, placi de retea, etc.si desigur verificat daca functioneaza. Altminteri, din ce se vede acel RAID controller sau HBA care se vede in poza, cel in care intra cablurile mini-SAS SFF 8087, valoreaza 30 de euro, carcasa serverului 80-100 de euro.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
