Jump to content
philips 14GR1227/02B
  • Replies 6
  • Created
  • Last Reply
Top Posters In This Topic
  • 1 year later...
Intrarea in serv. mode la acest model - numai pentru dezactivarea functiei HOTEL. (pentru cautare si volum maxim) : cu tv. pe canalul 38 se apasa store si vol.(-) la tastatura tv. Cu ch(-) si vol.(-)secomuta . Alta metoda este cea prezentata mai jos in original (ACTIVARE HOTEL)PHILIPS GR1-AX (8 buttons) GR1-AX (8 buttons) CTV Hotel mode for models with uP TMP47C434N-R221 Select program 38 on the TV Simultaneously press the STORE key on the TV and SLEEPTIMER on the remote for 4 about seconds (toggles hotel mode) Notes: The maximum volume in hotel mode will be the volume present when activating it STORE or INSTALL mode can not be entered The program number is displayed on the screen for 4 seconds A green 'H' appears in the left bottom of the screen, which can be removed by powering down the TV and powering it up again
Link to comment
Register a new account
Sign in
  • Create New...
Important Information
