mircea626 Posted November 19, 2005 Share Posted November 19, 2005 mircea626 sa zicem ca e identic in pini si se si poate citi,dar e posibil sa citeazca gresit unele adrese.Foloseste orion programer care il citeste perfect.nu am orion programer,dar am reusit cu ic prog.si inca o intrebare:la un car300f(cu hc05b16) ,dintr-o super prostie :axe: am reusit sa-i bag un continut total aiurea(confuzie) si acum nu mai buteaza.ce zici, m-am facut cu un procesor prost?mai pot face ceva cu el ,in afara de :toimonster: merci mult Quote Link to comment Share on other sites More sharing options...
goznerg Posted November 20, 2005 Author Share Posted November 20, 2005 Da pot sa-l faci sa buteze din nou dar trebuie sa resetezi procesorul cu asta: Quote Link to comment Share on other sites More sharing options...
fane Posted November 20, 2005 Share Posted November 20, 2005 bem berea am rezolvato. multam gabiz ro l-am lasat alim circa 24 ore dar tot SAFE. :drinkers: Quote Link to comment Share on other sites More sharing options...
gabiz_ro Posted November 20, 2005 Share Posted November 20, 2005 greseala mea.np.am crezut ca seamana cu beta5. Quote Link to comment Share on other sites More sharing options...
fane Posted November 20, 2005 Share Posted November 20, 2005 nici o probema orice sugestie este bine venita oricum toti putem face confuzii sau greseli . :drinkers: Quote Link to comment Share on other sites More sharing options...
exxu Posted November 20, 2005 Share Posted November 20, 2005 SalutMi-a adus cineva un cass auto pe care nu scrie decat asta:Ford Sound 2000iar pe o eticheta laterala: Ford 2004 89FB-18K876-BB C106483Dupa ce l-am alimentat am incercat sa introduc codul, dar nu prea imi permite, sau nu stiu eu; nu afiseaza decat trei linii: ---Ceva sugestii? Quote Link to comment Share on other sites More sharing options...
goznerg Posted November 20, 2005 Author Share Posted November 20, 2005 exxu lasa-l alimentat cam 60 min si incearca din nou cu but 1 2 3 si cu but 4 cred ca confirmi codul.Incearca deocamdata apoi mai vedem.Codul il ai ? Quote Link to comment Share on other sites More sharing options...
exxu Posted November 20, 2005 Share Posted November 20, 2005 Pe carcasa este notat un cod: 333Acum nu stiu si daca este valid.Ramane de vazut ... Quote Link to comment Share on other sites More sharing options...
gabiz_ro Posted November 21, 2005 Share Posted November 21, 2005 la un car300D nu reusesc sa boot-ez mcu.conectarea e urmatoarea gnd - gnd5v - pin 10pin9 - gndpin 11 - 10k la 5Vpin22 - 2k2 la 5Vpin19 - 10k la 10Vpin18 - reset max232 pin50 - tx max232pin52 - rx max232am incercat cu 22,50,52 cuplate si decuplate din circuit,schimbat tx cu rx,cu sau fara alimentare separata.dar degeaba.tot ce se intampla e sa palpaie ledul rosu de pe aparat la reset dar asta numai daca nu aplic cei 10V prin 10k in pin 19.am incercat cu motocracker 7 6 si 5.aparatul pare sa functioneze (e fara display),daca tin apasat pe as si-l pornesc se aude un beep.deci nu cred sa fie defect procesorul.orice idee e binevenita. Quote Link to comment Share on other sites More sharing options...
goznerg Posted November 26, 2005 Author Share Posted November 26, 2005 incearca cu 12v prin rez de 10 k.Daca nu atunci e problema de but a procesorului care nu afecteaza cu nimica functionarea perfecta a procesorului cand merge casul.Deci daca se aude bipul ala cind il pornesti asta nu are nimic cu partea de but al proc.trebe resetat procesorul cu un interface SELFCHECKO problema mare 12v prin rez de 10k nu 10v Quote Link to comment Share on other sites More sharing options...
gabiz_ro Posted November 27, 2005 Share Posted November 27, 2005 am incercat si cu 12 si cu 10 volti dar nu a mers.se vede ca s-au lipit fire pe placa deci cineva l-a mai citit sau a incercat sa-l citeasca.probabil are security bits activ.pe carcasa e notat un cod dar nu am reusit sa-l introduc pt ca e in "safe" (am facut un emulator de display).am incercat sa-l las pornit in speranta ca poate mai cere codul dar fiind in safe vad ca se opreste dupa ceva timp cam 2 ore.ramane sa fac interfata de selfcheck sa-l reseteze. Quote Link to comment Share on other sites More sharing options...
goznerg Posted November 28, 2005 Author Share Posted November 28, 2005 gabiz ro imi trimiti si mie schema cu interfata si tot ce mai apartine de el?Am si eu ceva schema luata de pe net cu interfata dar inca nu l-am facut.Daca tu spui ca merge al tau mi-ar trebui schema ta sa nu ma chinui pe degeaba,cine stie ce am eu luat de pe net.Ai schema pt.selfcheck sau sa tio trimit? Quote Link to comment Share on other sites More sharing options...
gabiz_ro Posted November 28, 2005 Share Posted November 28, 2005 pentru selfcheck parca e data in datasheet.asta e display emulator care a mers,dar cu mici probleme,nu prea se face reset bine la el pentru actualizarea lui trebuie deconectat-conectat. Quote Link to comment Share on other sites More sharing options...
goznerg Posted November 28, 2005 Author Share Posted November 28, 2005 In schema asta nici un integrat nu este? Quote Link to comment Share on other sites More sharing options...
gabiz_ro Posted November 28, 2005 Share Posted November 28, 2005 mai este una cu integrat.am facut-o si pe aia si a mers dar e acasa.abia spre seara daca ajung acasa sa o trimit si pe aceea.merg ambele dar doar cu versiuni mai vechi de display emulator.cu v3.0 cea de windows nu a mers niciuna.doar cu cele vechi de DOS.in functie de versiune difera schema.cea cu integrat parca e pentru prima versiune a programului.pentru cele mai noi 2.5 si 2.6 e cea cu un tranzistor. Quote Link to comment Share on other sites More sharing options...
Join the conversation
