Jump to content
kdl46ex653
 Share
  • Replies 16
  • Created
  • Last Reply
Top Posters In This Topic
Poate merge asa:
RESETTING THE TV TO FACTORY CONDITION USING
SERVICE MODE
1. Take the TV out of deep Standby mode by pressing POWER to
turn on the TV.
2. Press POWER to turn the TV back off.
3. Press the following buttons on the Remote Commander within a
second of each other:
"DISPLAY"  "5"  "Volume +"  "POWER"
4. If necessary, press JUMP or OPTIONS to go to DIGITAL menu.
5. Press the following buttons on the Remote Commander within a
Press 8 MUTE 0 .
“SERVICE” changes to green RST. RST executes the command and displays EXE.
EXE-RST displays green, then red indicating the TV is writing the
data.
Link to comment
Share on other sites
Acum 1 oră, gabiz_ro a spus:
Poate merge asa:
SERVICE MODE
turn on the TV.
Press 8 MUTE 0 .
data.
nu vrea nici de-al draqu
Link to comment
11 hours ago, paun nelu said:
am acest sony kdl46ex653 nu receptioneaza nici un program, am intrat in service si are tunerul in mod dezactivat si nu poti face absolut nici o modificare.
are cineva o solutie pt acest tv/ sincer cu sony sunt cam certat
Ar fi bine sa desfaci tv-ul si sa postezi seria placi de baza, ca sa gasim un dump pentru eeprom....asta trebuia sa o faci din prima postare ca doar esti user vechi cu experienta !
Edited by Costica Tv
Link to comment
fara suparare,
1-te-ai bagat in topicul omului si ai poluat subiectul,puteai deschide subiect ,,topic,, separat
2-daca ai inceput cu asa descriere de subiect  fara detalii nimic,ce ai masurat,......nu are rost sa ne mai pierdem timpul,cand tu insuti nu-ti dai interesul,daca nu te pricepi sa verifici componentele de baza,sigurante,rezistente,tensiuni,mai degraba abandonezi si cauti pe cineva ce se pricepe,si mai are rabdare la asemenea tv-uri
succes
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
  • Create New...
Important Information
