Mircea Posted September 30, 2020 Share Posted September 30, 2020 Pentru cei capabili sa lucreze cu reteaua exista solutia asta: Am tot zis sa incerc, astept zapada ca sa am mai multa motivatie. Asa scapi de relee si poti lucra elegant cu un switch de 12V. Quote Link to comment Share on other sites More sharing options...
Sharky Posted September 30, 2020 Share Posted September 30, 2020 De ce nu un simplu releu? Unul de 20A 250V~ e ieftin. Sau un releu solid state, dar ala e ceva mai scump. Logica oricum o alimentezi printr-un traf "de casetofon" Quote Link to comment Share on other sites More sharing options...
Mircea Posted September 30, 2020 Author Share Posted September 30, 2020 Releu 20A inductivi e greu spre imposibil de gasit. Plus dimensiunile. Depinde ce releu solid state folosesti, caci majoritatea fac comutarea la trecerea prin zero a tensiunii. Ceea ce nu e preferabil. Schema de mai sus tot un releu solid state, insa poti face comutarea cand tensiunea e in jurul valorii maxime. Cu avantajul aferent. Solutii exista pentru toate gusturile. Quote Link to comment Share on other sites More sharing options...
Sharky Posted September 30, 2020 Share Posted September 30, 2020 Stai un pic, e vb de releu de pus in primar nu ? Sau vb de protectie DC? Ca nu am urmarit tot sirul. Daca e vb de primar tine linistit. Nu e dracu chiar asa de negru. Quote Link to comment Share on other sites More sharing options...
sesebe Posted September 30, 2020 Share Posted September 30, 2020 (edited) @Mircea Și la releul solid state improvizat cine stinge "arcul electric" ce va apărea cind tai curentul pe virf de intensitate a curentului? Pui tranzistoare MOS-FET de 5000V? Edited September 30, 2020 by sesebe Quote Link to comment Share on other sites More sharing options...
Mircea Posted October 1, 2020 Author Share Posted October 1, 2020 Si ce, releului cu contacte mecanice cu izolatia tipica de 1kV si nu ii sunt afectate contactele? Acolo cine stinge arcul? Tot fara snubber. Stiu, o sa spui ca spike-ul e cu atat mai mare cu cat deschid mai repede. Aici ai dreptate, dar daca controlez timpul de deschidere... Quote Link to comment Share on other sites More sharing options...
djlove Posted October 1, 2020 Share Posted October 1, 2020 (edited) https://postimg.cc/gxP1BNCy Eu o sa merg pe schema asta pentru modulul de pornire a amplificatorului. Am dat comanda deja de 10 PCB-uri la JLC.... care vor arata asa, dimensiunea placi este 102 mm* 72 mm https://postimg.cc/0rYY0nC1 Edited October 1, 2020 by djlove Quote Link to comment Share on other sites More sharing options...
franzm Posted October 1, 2020 Share Posted October 1, 2020 Acum 4 ore, Mircea a spus: Stiu, o sa spui ca spike-ul e cu atat mai mare cu cat deschid mai repede. Aici ai dreptate, dar daca controlez timpul de deschidere... Dar daca îl conectati la maxim de tensiune si îl deconectati la minim? Quote Link to comment Share on other sites More sharing options...
sesebe Posted October 1, 2020 Share Posted October 1, 2020 (edited) Daca faci decuplarea la curent zero prin traf, asa cum face un unul detectie la trecerea prin zero, spikeul de autoinductie dispare. Conectarea la o tensiune diferita de zero nu este nici o problema, doar curentul creste brusc dar se prosupune ca exista rezerva pt acest caz. Edited October 1, 2020 by sesebe Quote Link to comment Share on other sites More sharing options...
Defro Posted October 1, 2020 Share Posted October 1, 2020 Acum 2 ore, djlove a spus: Eu o sa merg pe schema asta Adica proiectul de aici, sa avem si noi de rumegat ceva despre el. Quote Link to comment Share on other sites More sharing options...
Sharky Posted October 2, 2020 Share Posted October 2, 2020 E vorba de soft start + power off prin releu? Atunci e meeega simplu. Pornirea e prin soft start, deci nema spitz. Oprirea o faci prin soft "stop". Decuplezi releul care sunteaza rezistentele si apoi cu mica intarziere iei curentul. Quote Link to comment Share on other sites More sharing options...
Defro Posted October 2, 2020 Share Posted October 2, 2020 (edited) Niste baieti lucreaza de zor la problema asta. Edited October 2, 2020 by Defro Quote Link to comment Share on other sites More sharing options...
maxente Posted October 2, 2020 Share Posted October 2, 2020 Cine foloseste o sursa in comutatie, a scapat de stresul soft startului ( pe langa multe altele ) Quote Link to comment Share on other sites More sharing options...
Mircea Posted October 3, 2020 Author Share Posted October 3, 2020 Si SMPS-urile sufera de inrush. Quote Link to comment Share on other sites More sharing options...
Mircea Posted October 3, 2020 Author Share Posted October 3, 2020 On 10/1/2020 at 1:45 AM, franzm said: Dar daca îl conectati la maxim de tensiune si îl deconectati la minim? Am sapat un pic, si ca sa simplific la minimum numarul de piese, am ales sa testez o functionare cu un PIC care stie ZCD. Astfel, ma pot juca cum vreau cu momentul in care comand. Practic, in plus la schema cu mosfetii avem un integrat de 14 pini (nu exista ZCD la 8 pini), o rezistenta, un condensator de filtrare si un condensator de decuplare. Restul e soft. ZCD (zero cross detection) este o functie care permite aplicarea tensiunii de retea printr-o rezistenta de limitare (cat sa fie sub 300uA). Ca sa se evite zbarnaiala intrarii ZCD se filtreaza cu cativa zeci de pF. Astfel exista o intarziere de cateva zeci de usec la detectie. Infim comparativ cu cei 4-5ms (la 60 sau 50Hz) ai unui sfert de alternanta. E fezabil. Quote Link to comment Share on other sites More sharing options...
Join the conversation
