bogdan666 Postat August 14, 2020 Partajează Postat August 14, 2020 (editat) Am facut un incarcator solar cu arduino, si am urmatoarea problema cu senzorul de curent, cand nu trece curent prin el ar trebui sa fie 0V, dar defapt e 0.590V, care e citit de un adc, si anume ads1115. Cum pot sa spun adc-ului sa inceapa numaratoarea doar de la 590mV? #include <Wire.h> #include <LiquidCrystal_I2C.h> LiquidCrystal_I2C lcd(0x27, 20, 4); #include <Adafruit_ADS1015.h> Adafruit_ADS1115 ads(0x4A); float V1 = 0.0; float V2 = 0.0; float V3 = 0.0; float V4 = 0.0; float en1 = 0.0; float en2 = 0.0; void setup(void) { pinMode(9, OUTPUT); lcd.init(); lcd.backlight(); Serial.begin(9600); ads.begin(); } unsigned long startMillis; unsigned long currentMillis; unsigned long elapsedMillis; byte pulseWidth = 0; void loop(void) { V1 = ((ads.readADC_SingleEnded(0)) * 0.0001875) * 7; V2 = ((ads.readADC_SingleEnded(1)) * 0.0001875) * 20; V3 = ((ads.readADC_SingleEnded(2)) * 0.0001875) * 10; V4 = ((ads.readADC_SingleEnded(3)) * 0.0001875) * 8; currentMillis = millis(); elapsedMillis = (currentMillis - startMillis); unsigned long SS = (elapsedMillis / 1000) % 60; unsigned long MM = (elapsedMillis / (60000)) % 60; unsigned long HH = (elapsedMillis / (3600000)); en1 = en1 += (V3 * V4) * 1 / 36000; en2 = en2 += (V1 * V2) * 1 / 36000; lcd.setCursor(0, 0); lcd.print(V4, 2); lcd.setCursor(5, 0); lcd.print("V"); lcd.setCursor(7, 0); lcd.print(V3, 3); lcd.setCursor(12, 0); lcd.print("A"); lcd.setCursor(14, 0); lcd.print(V3 * V4, 1); lcd.setCursor(19, 0); lcd.print("W"); lcd.setCursor(0, 1); lcd.print(V1, 3); lcd.setCursor(5, 1); lcd.print("V"); lcd.setCursor(7, 1); lcd.print(V2, 3); lcd.setCursor(12, 1); lcd.print("A"); lcd.setCursor(14, 1); lcd.print(V1 * V2, 1); lcd.setCursor(19, 1); lcd.print("W"); lcd.setCursor(0, 2); lcd.print("IN"); lcd.setCursor(4, 2); lcd.print(en1, 1); lcd.setCursor(10, 2); lcd.print("W/H"); lcd.setCursor(0, 3); lcd.print("OUT"); lcd.setCursor(4, 3); lcd.print(en2, 1); lcd.setCursor(10, 3); lcd.print("W/H"); lcd.setCursor(14, 3); lcd.print(MM); lcd.print(":"); lcd.print(SS); if (V1 < 28 ) { if (pulseWidth != 255) pulseWidth++; } if (V1 > 28 ) { if (pulseWidth = 0); } analogWrite(9, pulseWidth); } Editat August 14, 2020 de bogdan666 Citează Link spre comentariu
Elison Postat August 14, 2020 Partajează Postat August 14, 2020 Cum arata ACS 748 ? Citează Link spre comentariu
bogdan666 Postat August 14, 2020 Autor Partajează Postat August 14, 2020 acs758, greseala mea, scuze... Citează Link spre comentariu
mihaicozac Postat August 14, 2020 Partajează Postat August 14, 2020 Dacă citeşti direct milivolţi, compensarea se face simplu. După linia de citire adc, mai introduci una: V1 = V1 - 590; Citează Link spre comentariu
bogdan666 Postat August 14, 2020 Autor Partajează Postat August 14, 2020 Foarte simplu...dupa mai multe teste, defapt functioneaza cu 588: V2 = (((ads.readADC_SingleEnded(1)) * 0.0001875) - 0.588) * 20; mersi mult, o alta problema este faptul ca ecranul o ia razna cand chiar se foloseste energie, deci trebuie sa rotunjesc citirile...inapoi la studiat. Citează Link spre comentariu
bogdan666 Postat August 16, 2020 Autor Partajează Postat August 16, 2020 Poate intereseaza pe cineva sau are aceeasi problema, am rezolvat problema cu "rotunjirile" V1 = 0; V2 = 0; V3 = 0; V4 = 0; for (int i = 0; i < 10; i++) { V1 += ads.readADC_SingleEnded(0) * 0.0001875 * 7.0; V2 += (ads.readADC_SingleEnded(1) * 0.0001875 - 0.588) * 20; V3 += (ads.readADC_SingleEnded(2) * 0.0001875 - 0.588) * 10; V4 += ads.readADC_SingleEnded(3) * 0.0001875 * 8.0; delay(1); } V1 /= 10; V2 /= 10; V3 /= 10; V4 /= 10; Citează Link spre comentariu
Liviu M Postat August 16, 2020 Partajează Postat August 16, 2020 Felicitari pentru rezolvarea problemei, numai ca metoda folosita nu-i rotunjire, e mediere - calculezi media unui numar de masuratori (in cazul tau 10). Stiu, teoria chbritului... Citează Link spre comentariu
bogdan666 Postat August 16, 2020 Autor Partajează Postat August 16, 2020 Da, media celor 10 masuratori, e adevarat. Citează Link spre comentariu
Alătură-te conversației
Poți posta acum și să te înregistrezi mai târziu. Dacă ai un cont, autentifică-te acum pentru a posta cu contul tău.
Notă: Postarea ta va necesita aprobare moderator înainte de a fi vizibilă.
