tuffguy Posted January 14, 2005 Share Posted January 14, 2005 am facut montajul dar acuma am probleme cu configurareain bios la mine am optiunile:uart mode: Normal, IrDA, ASKIRRxd Txd Active: Hi Hi, Hi Lo, Lo Hi, Lo LoIR Transmision Delay: Enabled, DisabledUR2 Duplex Mode: Half. FullUse IR Pins: IR-Rx2Tx2, RxD2, TxD2Prea multi parametri. Cum naiba sa-i setezi pe toti ca sa-mi mearga??? Link to comment
tuffguy Posted January 19, 2005 Author Share Posted January 19, 2005 SI CU INTREBARILE MELE CUM RAMANE. pLEASE HELP!!!!!!!! Link to comment
cniky Posted January 20, 2005 Share Posted January 20, 2005 ti-am extras topicurile tale de la "Cumpar TFDS 4500", si am creat un topic nou ce l-am mutat la Consultanta,sper ca e OK asa... :wink: Link to comment
tuffguy Posted January 25, 2005 Author Share Posted January 25, 2005 ok dar sa stii ca am aflat cam tarziu si nu stiam ce s-a intamplat. Erem nemultumit ca de ce mi-a disparut topicul.... Link to comment
Guest Robert Posted January 26, 2005 Share Posted January 26, 2005 Astept si eu raspunul la aceleasi intrebari. Am facut interfatza cu transc. luat de pe o placa de Erics.r320 ...4100 sau ceva de genu' asta ... am facut-o dupa schema din datasheet. Problema e ca am intampinat greutatzi la instalare, nu prea ma descurc cu setarile in bios. Link to comment
