Blacksmith Posted September 12, 2007 Share Posted September 12, 2007 Salut. Am facut si eu schema postata de Sharky in primul thread si nu-mi merge. http://www.elforum.info/download.php?id=9671 Exact cum e acolo cu IRFP450. (deci NU varianta lui Vasile cu IRFP240) O alimentez la +/- 75V si imi distorsioneaza de nu pot sa scot nici 1W. Dar eu am alimentat dintr-un traf de 100W cu 5000uF filtraj. Oricum nu vream sa-i cer mai mult de 50W, vream sa vad doar daca merge.... asa... ca nu mai am rabdare pina imi comand un traf de 1KW (ampu avind 2 x 300W ). Dar sa vezi ce chestie : cind o alimentez la +/- 40 (bineinteles, cu cele 2 rezistente modificate corespunzator) merge de rupe ! frumosssss ... fara distorsiunii.... am scos 60W curati. Pe acelasi traf de 100W !! Nustiu ce sa-i mai fac .... nu e pacat s-o las moarta asa ? :smt005 http://www.audio-electronics.go.ro ( site-u meu, pt. poze ) Quote Link to comment Share on other sites More sharing options...
George(sb) Posted September 12, 2007 Share Posted September 12, 2007 probabil piesele consuma mai mult decat puterea transformatorului, si atunci e normal Quote Link to comment Share on other sites More sharing options...
Blacksmith Posted September 12, 2007 Author Share Posted September 12, 2007 Care piese ? Quote Link to comment Share on other sites More sharing options...
cosmin_h Posted September 12, 2007 Share Posted September 12, 2007 Care piese ?Adica amplificatorul (care contine piese) consuma mai mult decat ii poate livra acel transformator de 100 W Quote Link to comment Share on other sites More sharing options...
Blacksmith Posted September 12, 2007 Author Share Posted September 12, 2007 tot consumu in gol este de 20W .... mai are pina la 100 :rolleyes: Quote Link to comment Share on other sites More sharing options...
vio2007 Posted September 12, 2007 Share Posted September 12, 2007 Dar sa vezi ce chestie : cind o alimentez la +/- 40 (bineinteles, cu cele 2 rezistente modificate corespunzator) merge de rupe ! frumosssss ... fara distorsiunii.... am scos 60W curati. Pe acelasi traf de 100W !! Daca merge cum spui mai sus , o folosesti asa pana primesti traful de 1kW, mai folosesti si pentru celalalt canal un traf asemanator +/-40V de 100W si ai 2X60W.O alimentez la +/- 75V si imi distorsioneaza de nu pot sa scot nici 1W. Masoara tensiunea sa vezi cat scade si ce curent consuma din sursa cu traful de 100W si posteza valorile aici. Quote Link to comment Share on other sites More sharing options...
Blacksmith Posted September 12, 2007 Author Share Posted September 12, 2007 O sa masor miine.Daca am doua trafuri de 100W .... pot sa le leg ca in imagine sa fac unul mai mare ? :smt003(defapt unu e de 125W si altu de 190W; si nu, m-am cum sa-l folosesc doar p-ala de 190W ca nu am tensiunile care trebuie, decit 2 x30 sau 1 x 60)EDIT : am updatat schema cum am facut (si merge trafu, scoate cum trebuie) Quote Link to comment Share on other sites More sharing options...
Dr.L Posted September 12, 2007 Share Posted September 12, 2007 daca ai,pune mai bine 2 puni redresoare+conzii aferenti apoi le legi ca sa faci sursa simetrica(masa e formata sin +ul unuia si -ul altuia) Quote Link to comment Share on other sites More sharing options...
zal Posted September 12, 2007 Share Posted September 12, 2007 Daca am doua trafuri de 100W .... pot sa le leg ca in imagine sa fac unul mai mare ? :smt003(defapt unu e de 125W si altu de 190W; si nu, m-am cum sa-l folosesc doar p-ala de 190W ca nu am tensiunile care trebuie, decit 2 x30 sau 1 x 60)Da e corect asa chiar daca ai diferente de putere. Se admite maxim un raport de 1 la 3 intre puterile a 2 trafo diferite. Quote Link to comment Share on other sites More sharing options...
Guest yGs Posted September 13, 2007 Share Posted September 13, 2007 intrebarea e asa.. i-ai reglat tensiunile de mers in gol.. cum spune in specificatii ? :smt006 Quote Link to comment Share on other sites More sharing options...
Blacksmith Posted September 13, 2007 Author Share Posted September 13, 2007 Aata e ce am testat astazi cu cele 2 trafuri legate ca mai sus. Alimentarea e +/-83V si scade nesemnificativ in sarcina (~1V). La fel distorsioneaza... exact ca inainte ... :smt090 nici o schimbare ... dar observati ca semiperioada de jos nu e distorsionata .... ? :chior: Quote Link to comment Share on other sites More sharing options...
Blacksmith Posted September 13, 2007 Author Share Posted September 13, 2007 intrebarea e asa.. i-ai reglat tensiunile de mers in gol.. cum spune in specificatii ? :smt006da, i-am reglat totul cum spune in specificatii :* [ 1.44 mA / 1.44 mA / 2.98 mA ] - la intrare* [ 15.1 mA ] - la T6-T7* [ 16.4 mA ] - la T9-T10* [ 30 mA/pereche ] - la mosfeti Quote Link to comment Share on other sites More sharing options...
Blacksmith Posted September 13, 2007 Author Share Posted September 13, 2007 mosfetii cum trebuie imperechiati : cei de sus intre ei sa fie la fel si cei de jos intre ei sa fie la fel ? sau unu de sus cu unu de jos sa fie la fel ? Quote Link to comment Share on other sites More sharing options...
cirip Posted September 13, 2007 Share Posted September 13, 2007 Amplifu' lu' matale oscileaza de-i sare palaria. Galma aia de pe alternanta pozitive e oscilatie, dar pe care nu o vezi ca atare datorita benzii de frecventa insuficiente a osciloscopului (probabil placa de sunet).Solutie? Hm... , nu e simplu, dar ptr inceput poti sa incerci sa maresti C8.Cirip Quote Link to comment Share on other sites More sharing options...
florin01 Posted September 13, 2007 Share Posted September 13, 2007 Montajul este cel de pe site? Pe montajul acela nu ai pus o rezistenta (R6) langa la T4 http://tinypic.com/view.php?pic=4thp79f&s=1 Edit: mda in primele poze nu este pusa :smt005 Quote Link to comment Share on other sites More sharing options...
Join the conversation
