poplex22 Posted February 15, 2020 Share Posted February 15, 2020 am in lucru un philips 32'' pe sasiu chinezesc : 715G9287-C01-002 , rog cine are in lucru sau la indemana o placa de acest tip cu PF6005A in sursa sa-mi spuna si mie sau sa-mi puna o poza cu zona de sursa pt. ca am citeva componente carbonizate si nu stiu ce valori au : R9111, R9112, R9104, R9107, C9103, orice ajutor e binevenit Link to comment
zvasile Posted February 15, 2020 Share Posted February 15, 2020 o schema gasiti aici,vedeti daca se potriveste..... Link to comment
poplex22 Posted February 15, 2020 Author Share Posted February 15, 2020 din pacate nu se potriveste, fac poza si o voi anexa Link to comment
poplex22 Posted February 15, 2020 Author Share Posted February 15, 2020 iata cum arata placa cu pricina dupa ce am mai curatat zona afectata din sursa Link to comment
Gabriel_S Posted February 15, 2020 Share Posted February 15, 2020 În secundar are o singura tensiune de 12v? Link to comment
megabit Posted February 15, 2020 Share Posted February 15, 2020 sasiu chinezesc : 715G9287-C01-002 , Pare un sasiu cu serie scurta, sau limitata ! Link to comment
Tavi Posted February 15, 2020 Share Posted February 15, 2020 La Philips spuneti sasiul cand cereti ceva S-a mai spus de o suta de ori Se va mai spune de o mie Dar atat se poate Link to comment
poplex22 Posted February 16, 2020 Author Share Posted February 16, 2020 sasiul complet este : 715G9287 C01 002 004Y, dupa cum v-am spus am nevoie de valoarea componentelor enumerate sau poza cu zona lor, mersi Link to comment
validae Posted February 17, 2020 Share Posted February 17, 2020 În prima poză apare clar un număr, ce pare a fi al şasiului...dar poate ar fi bine să puneţi o poză cu eticheta de pe spatele televizorului, uneori acolo se specifică şi asta. Link to comment
Costica Tv Posted February 17, 2020 Share Posted February 17, 2020 (edited) PHILIPS 32PHT4503/12, sasiu TPN18.1E LA, repar da multa vreme tv PHILIPS si stiu exact ce spun, altfel nu postam.....intodeauna la tv lcd ,Philips, Grundig..etc, seria sasiului se gaseste doar pe eticheta de pe capac ci nu pe placa de baza !!! Edited February 17, 2020 by Costica Tv Link to comment
ROBEERT Posted February 17, 2020 Share Posted February 17, 2020 (edited) La 15.02.2020 la 22:07, poplex22 a spus: am in lucru un philips 32'' pe sasiu chinezesc : 715G9287-C01-002 , rog cine are in lucru sau la indemana o placa de acest tip cu PF6005A in sursa sa-mi spuna si mie sau sa-mi puna o poza cu zona de sursa pt. ca am citeva componente carbonizate si nu stiu ce valori au : R9111, R9112, R9104, R9107, C9103, orice ajutor e binevenit PF6005 este cu 2X4 pini sau cu 2X3 pini? Atentie, sunt doua feluri ( vedeti pozele din linkul urmator ): https://www.google.com/search?q=PF6005A&tbm=isch&source=univ&sa=X&ved=2ahUKEwj7-7TcwNnnAhX7AxAIHecvBigQsAR6BAgKEAE&biw=1152&bih=753 Daca nu va ajuta vreun coleg pe forum cu valorile componentelor arse, cautati datashetul PF-ului 6005 si orientati-va la valorile acelor rezistoare. P.S. As crede ca aceste Philipsuri sunt modelele noi aparute recent. Asa sunt noile modele. Sunt cu placi China asemanator Vortexurilor si a altor orezarii chinezesti. Inca nu am reparat asa ceva, dar am vazut la un prietenas care a lucrat la Altex. Cand m-am dus intr-o zi la el, nu stiu cum am avut " inertia " sa ma uit la un asemenea Philips pe capac si i-am zis intre patru ochi, citez: " prietene, Philipsurile astea sunt orezarii chinezesti. Nu sunt Philipsurile traditionale care le stim cu totii. Il cunosc dupa capacul care se desface in forma de T exact ca la celelalte orezarii ( Vortex, Vinchi, Toshiba, etc ) ". Si uite ca s-a adeverit ca sunt orezarii chinezesti. Celelalte feluri de Philips echipate cu PF6005 am reparat multe si am avut si eu rezistoare intrerupte ( nu arse ) si am putut sa le citesc valorile. Oricum, exista schema, dar multe cazuri am avut ca pe schema scria o valoare si pe cablaj era alta valoare. In ultima instanta, daca aveti in sursa numai 12 volti, ii puteti adapta foarte usor o sursa ( inclusiv externa ). Dar si sursele externe eu le desfac si montez simpla placa in televizor daca am loc. Edited February 17, 2020 by ROBEERT Link to comment
Costica Tv Posted February 18, 2020 Share Posted February 18, 2020 La ce mai pierdeti timpul de pomana, poate nu ati fost pe faza, omul a rezolvat tv-ul si a incasat bani.....sa sters din postari, de-aia nu se mai intelege nimic.....si asa topicul nu are nici-o rezolvare.... Link to comment
sciurca Posted February 21, 2020 Share Posted February 21, 2020 Replied: Monday at 09:02 AM Buna dimineata. Vad ca nu pot insera fotografii in conversatie. Aveti asa: R9111 47 ohmi cod 470 R9112 22 ohmi cod 220 R9104 1 ohm cod 010 R9107 750 ohmi cod 751. C9103 cred ca il puteti gasi in datasheetul ic ului sau intr-o aplicatie a ic ului. Link to comment
