catax4u Posted January 11, 2020 Share Posted January 11, 2020 Salut. Se poate face un letcon suficient de puternic avand ca piesa principala o bujie auto incandescenta alim la 12 VCC? Am auzit de varianta asta dar nu am vazut efectiv unul. Link to comment
mac01 Posted January 11, 2020 Share Posted January 11, 2020 Bujia incandescenta are nevoie de un curent de 15-30A. Sa nu mai vorbim de faptul ca nu o poti tine mult timp la intensitate maxima...se va arde. Ea este prevazuta sa functioneze cateva secunde si apoi se opreste. Daca faci o sursa reglabila...sa zicem 4-12v care sa tina curentul mai sus mentionat atunci da...poti face o sursa de caldura care sa topeasca fludorul... Link to comment
Haralambie Posted January 11, 2020 Share Posted January 11, 2020 (edited) Sa sudezi burlane doar. Sau rezervoare de dacie Problema e ca distrugi totul, ele fiind facute sa urce pana la 1000-1200 grade C Edited January 11, 2020 by Haralambie Link to comment
doru3160 Posted January 11, 2020 Share Posted January 11, 2020 Acum 2 ore, catax4u a spus: Se poate face un letcon suficient de puternic avand ca piesa principala o bujie auto incandescenta alim la 12 VCC? Asta merge pusa la Radio Erevan. Cand am vazut clipul de mai sus, m-am mirat cum de nu a folosit un incarcator de telefon, si a folosit o baterie de 7Ah. Firisoarele alea ard instant la consumul bujiei...dar pe net, orice e posibil. Link to comment
mac01 Posted January 11, 2020 Share Posted January 11, 2020 (edited) Sa nu mai vorbim de acel push button (micro switch) care suporta miliamperi...in nici un caz amperi. Se topeste instant la prima actionare. Edited January 11, 2020 by mac01 Link to comment
Guest Posted January 11, 2020 Share Posted January 11, 2020 E posibil ca acel msw sa actioneze poarta unui mosfet. La clip nu m-am uitat. Link to comment
Barbu Andrei Posted January 11, 2020 Share Posted January 11, 2020 Pai daca incalzeste degetul, inseamna ca incalzeste si bujia. Ca sa intelegeti : intrerupatorul ala are rol si de senzor de temperatura. ON - Ar merge facut unul, dar alimentat la tensiuni mult mai mici. Si asta doar pentru distractie. Oricum, un letcon echivalent cu montajul asta costa mai putin decat o bujie. 1 Link to comment
doru3160 Posted January 11, 2020 Share Posted January 11, 2020 Acum 30 minute, DjLeco a spus: La clip nu m-am uitat. N-ai pierdut mare lucru, nici macar mosfetul...ca nu e. Link to comment
ionutb71 Posted January 12, 2020 Share Posted January 12, 2020 candva,cred acu 20 de ani,mi-am construit asa ceva. am facut pe strung o teaca de cupru in care am infiletat bujia. ideea e sa se asigure un contact bun intre teaca si electrod. cred ca inca il mai am si bujia e aceeasi . bujie trebuie de la modele mai vechi de motoare,cele cu inrosire la aprox 25 secunde. curentul absorbit undeva la 8A,la o tensiune intre 4-7V. este util la cositorirea cablurilor groase,perii electromotor etc. Link to comment
doru3160 Posted January 12, 2020 Share Posted January 12, 2020 (edited) 1 oră în urmă, ionutb71 a spus: este util la cositorirea cablurilor groase,perii electromotor etc. La asemenea lucrari e importanta inertia termica a varfului de lipit. Cu cat e mai masiv, cu atat te ajuta mai mult, daca nu te incurca la manevrat. In asemenea situatii incalzirea cu flacara/gaz ramane o optiune viabila. Sunt jucarii de lipit cu lampa de gaz atasata. Bujia aia se incalzeste tare, poate mult prea tare, dar poate fi considerata o sursa de caldura, mai ales ocazionala si in protectie de cupru, parca pare mai aproape de ce ar trebui sa fie si sa faca, decat ce a fost prezentat in clipul ala. Ala poate fi considerat o gluma buna. Daca in teaca aia de cupru se face loc si pt un termocuplu, treaba devine serioasa, si de luat in seama. Edited January 12, 2020 by doru3160 Link to comment
pop_ady44 Posted January 12, 2020 Share Posted January 12, 2020 (edited) Acum 16 minute, doru3160 a spus: Daca in teaca aia de cupru se face loc si pt un termocuplu, treaba devine serioasa, si de luat in seama. Am facut o astfel de „statie” pentru un cumnat care este strungar si mai face si cate un electromotor . El a venit cu ideea de letcon din cupru eu l-am termostatat . Mai greu a fost sa gasim un traf de 10 volti si 15 A sa reziste la gluma .(bujia consuma cam 12-13 A la inrosire si scadea pe la 7-8 la mentinere ) Termostatarea este pe schema WOLF si termocupla este recuperata dintrun letcon miva ieftin care sa ars in teaca de cupru de la bujie sa pus pasta termica cu argint mai greu a fost la termocuplu sa-i asiguri un contact cat mai perfect si sa nu o nici spargi.(fiind un tub gen dioda 1n41xx) Merge de vreo 4-5 ani ocazional cate 10-20 minute si pe urma trece pe raft. L-am lasat cam 20 ore pornit sa vedem ce va face si nu sa distrus elementul de incalzire,cu toate ca e fost dat la maxim 480-500 grade. PS Mai este un detaliu de luat in seama cele 2 fire care alimenteaza bujia trebuie destul de sanatoase(groase) Edited January 12, 2020 by pop_ady44 Link to comment
Haralambie Posted January 12, 2020 Share Posted January 12, 2020 Important este transferul termic la teaca si ulterior la piesa Link to comment
pop_ady44 Posted January 12, 2020 Share Posted January 12, 2020 Exact cum spune colegu @Haralambie, transferul termic este important, si cat de fixa este piesa de infiletare care ori cum cu timpu se va decalibra ,din cauza incalziri raciri repetate . Link to comment
doru3160 Posted January 12, 2020 Share Posted January 12, 2020 (edited) Acum 42 minute, pop_ady44 a spus: Mai este un detaliu de luat in seama cele 2 fire care alimenteaza bujia trebuie destul de sanatoase(groase) Adica asa, ca cele din clip, si suficient de lungi... Edited January 12, 2020 by doru3160 Link to comment
pop_ady44 Posted January 12, 2020 Share Posted January 12, 2020 (edited) Exact asa cum spui . Vai vai ce ti si cu modermismu asta spuse Baba .Nu mai gasesti nimic ce unde scrie . Edited January 12, 2020 by pop_ady44 Link to comment
