Mar Posted January 17, 2005 Share Posted January 17, 2005 As vrea sa compar starile logice ale registrului ADRESH (conversia A/D)In momentul in care tensiunea pe intrare variaza sa vor modifica si starile logice din ADRESH.Eu am o ideie cum sa selectez si sa compar din cele 255 de stari ale registrului ADRESH dar e prea complicat.Iata un exempluDaca in registrul ADRESH se afla starea: 00001010 eu pot compara si verifica cu:label btfcs ADRESH.0 goto label btfss ADRESH,1 goto label btfcs ADRESH.2 goto label btfss ADRESH,3 goto label btfcs ADRESH,4 goto label btfcs ADRESH,5 goto label btfcs ADRESH,6 goto label btfcs ADRESH,7 goto label call oriceStiti voi ceva mai simplu? Link to comment
Cristiano Posted January 17, 2005 Share Posted January 17, 2005 Pt. PIC16xxxx poti folosi instructiuni de tip XOR, in caz de egalitate, rezultatul va fi nul si bitul Z din reg. STATUS setat. Eu am scris cateva macro-uri pt. astfel de operatii: ;=================================================================================; => EqualTo : checks if a reg.(number) is equal to a given value (literal): =; if number==val then goto label_yes; else goto label_no;---------------------------------------------------------------------------------EqualTo macro number, val, label_yes, label_no movlw val xorwf number, W btfsc _Z goto label_yes goto label_no endm;=================================================================================;=================================================================================; => EqualToReg : checks if a reg.(number) is equal to a given value (register): =; if number==reg then goto label_yes; else goto label_no;---------------------------------------------------------------------------------EqualToReg macro number, reg, label_yes, label_no movfw reg xorwf number, W btfsc _Z goto label_yes goto label_no endm;================================================================================= Alte macro-uri utile: ;=================================================================================; => Between : checks if a reg.(number) is in an interval (given by literals): [ ... ); if min<=number<max then goto label_yes; else goto label_no;---------------------------------------------------------------------------------Between macro number, min, max, label_yes, label_no movlw min subwf number, W btfss _C goto label_no movlw max subwf number, W btfsc _C goto label_no goto label_yes endm;=================================================================================;=================================================================================; => LessThan : checks if a reg.(number) is less than a given value (literal): <; if number<val then goto label_yes; else goto label_no;---------------------------------------------------------------------------------LessThan macro number, val, label_yes, label_no movlw val subwf number, W btfss _C goto label_yes goto label_no endm;=================================================================================;=================================================================================; => LessThanReg : checks if a reg.(number) is less than a given value (register): <; if number<reg then goto label_yes; else goto label_no;---------------------------------------------------------------------------------LessThanReg macro number, reg, label_yes, label_no movfw reg subwf number, W btfss _C goto label_yes goto label_no endm;================================================================================;=================================================================================; => LessOrEqualReg : checks if a reg.(number) is less than a given value (register): <=; if number<=reg then goto label_yes; else goto label_no;---------------------------------------------------------------------------------LessOrEqualReg macro number, reg, label_yes, label_no movfw number subwf reg, W btfss _C goto label_no goto label_yes endm;================================================================================ Edit: Exemple de utilizare: cblock 0x20 A, B, C, Dendc.......LessOrEqualReg A, B, L_Y1, L_N1 ...........L_Y1: ....... ;; Executed if A<=B.......L_N1: ....... ;; Executed if A>B...........EqualTo A, .56, L_Y2, L_N2...........L_Y2: ....... ;; Executed if A==56.......L_N2: ....... ;; Executed if A!=56 Link to comment
cirip Posted January 17, 2005 Share Posted January 17, 2005 Corect. Xorul iti detecteaza egalitatea intre 2 octeti.Daca vrei sa rafinezi un pic si lucrezi numai pe 8 biti (un registru), poti efectua o scadere intre valoarea variabilei (ADRESH in cazul tau) si valoarea pragului (de ex o constanta). Ai grija sa nu distrugi variabilele in urma operatiei. In fct de relatia dintre cele doua valori, se vor seta/reseta corespunzator Z si C. Experimenteaza un pic cu simulatorul, ca sa vezi ce si cum se intampla.Cirip Link to comment
