Guest adrian ploiesti Posted August 7, 2019 Share Posted August 7, 2019 Buna seara, am un Tv Philips 40pft4100/12 cu defectul prezentat in video --> https://streamable.com/hobb9 . Daca il las asa, uneori in cateva minute isi revine, dar dupa un timp de functionare defectul reapare . S-a mai confruntat cineva cu acest defect ? O idee !? Multumesc ! Link to comment
Guest Posted August 8, 2019 Share Posted August 8, 2019 Salutare. Incearca cu chitul de reparare. http://www.filehost.ro/3172429450/upgrade_loader_pkg/ Pui pe un stick gol,il bagi la USB,apoi apesi pe tasta ok ~ 1 min, bagi tv-ul in priza. Incearca,daca nu functioneaza,rescrie memoria . eu personal nu am un bin..poate au colegii. Spor. Link to comment
Florinel TV Posted August 8, 2019 Share Posted August 8, 2019 Acest tv are nand si de acolo este problema , sau se intra in service si se da reset Link to comment
yokoono Posted August 8, 2019 Share Posted August 8, 2019 Sau instalezi ultimul soft de la producator https://www.philips.ro/c-p/40PFT4100_12/4000-series-led-tv-subtire-full-hd-cu-digital-crystal-clear/support Link to comment
Guest Posted August 10, 2019 Share Posted August 10, 2019 (edited) La 3 postari din 2015 cred ca ai primit destul ajutor din partea forumului ca sa nu mai zic si rezolvarea defectului.... Edited August 10, 2019 by Guest Link to comment
Guest Posted August 10, 2019 Share Posted August 10, 2019 Defectul la tv se numeste (modul test) nu se rezolva cu stickul. Link to comment
clony Posted August 12, 2019 Share Posted August 12, 2019 A intrat in burn mode. Problema cred ca e la LVDS, contacte imperfecte sau alt cablu.. Link to comment
Guest adrian ploiesti Posted September 6, 2019 Share Posted September 6, 2019 Buna ziua, am rezolvat defectul inca de pe atunci, scuze pentru reactia intarziata ! Acest Tv are panglica LVDS compusa din 2 bucati , intre cele 2 se afla un adaptor cu 2 conectori montati pe un PCB , clientul a avut Tv la garantie in service , cei de acolo si-au batut joc de acesti 2 conectori , contacte rupte , indoite .... Am inlocuit acest adaptor . Va multumesc pentru raspunsuri ! Link to comment
