Jump to content
Senzor gaz cu Neopixel
Guest James Bond
Guest James Bond
Salut
vreau sa fac un senzr de gaz cu neopixel si nu reusesc sa ii dau de capat, eu vreau sa combin cele doua coduri, mai exact vreau ca si codul de neopixel sa intre in functia IF al conditiei senzorului. cum il pot scrie ca atunci cand detecteaza gzul sa porneasca jocl de lumini?
// viral science
// gas sensor
int redLed = 12; //led red
int greenLed = 11; //led green
int buzzer = 10; //buzzer
int smokeA0 = A5; //mq2 sensor
int sensorThres = 620; //change the threshold value asper your need
void setup() {
  pinMode(redLed, OUTPUT);
  pinMode(greenLed, OUTPUT);
  pinMode(buzzer, OUTPUT);
  pinMode(smokeA0, INPUT);
  Serial.begin(9600);
void loop() {
  int analogSensor = analogRead(smokeA0);
  Serial.print("Pin A0: ");
  Serial.println(analogSensor);
  if (analogSensor > sensorThres) //checks if it has reached threshold value
    digitalWrite(redLed, HIGH);
    digitalWrite(greenLed, LOW);
    tone(buzzer, 1000, 200);
  else
    digitalWrite(redLed, LOW);
    digitalWrite(greenLed, HIGH);
    noTone(buzzer);
  delay(100);
si neopixel
// Left as-is from the example
#include <Adafruit_NeoPixel.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 5
// All of this stuff below is from the example
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(8, PIN, NEO_GRB + NEO_KHZ800);
//NOTE: I tested this code with an 8 LED module, but you should be able to daisy chain multiple modules
//NOTE: Try changing the "8" to "4" to see how it reacts.
// This warning is from the example, probably worth considering
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel.  Avoid connecting
// on a live circuit...if you must, connect GND first.
void setup() {
  // This stuff is from the example, I commented it out since I am not using a Trinket
  // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
  //#if defined (__AVR_ATtiny85__)
  // if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
  //#endif
  // End of trinket special code
  strip.begin();
  strip.show();
void loop() {
  // This is a 2 color wigwag
  WigWag2(strip.Color(255, 0, 0), strip.Color(255, 0, 0), 200); // Blue and Red
//  ClearLights();
  delay(10);
void WigWag2(uint32_t c, uint32_t c2, uint8_t wait) {
  for (int j = 0; j < 20; j++) { // The j<# determines how many cycles
    for (int i = 0; i < strip.numPixels(); i = i + 1) {
      strip.setPixelColor(i, c);
    for (int i = (strip.numPixels() / 2); i < strip.numPixels(); i = i + 1) {
      strip.setPixelColor(i, 0);
    strip.show();
    delay(wait);
      strip.setPixelColor(i, c2);
    strip.show();
    delay(wait);
Link to comment
  • Replies 5
  • Created
  • Last Reply
Top Posters In This Topic
Register a new account
Sign in
  • Create New...
Important Information
