Jump to content
LG 32LF510U NU MEMOREAZA PROGRAMELE
Am un LG 32LF510U, sasiu EAX 66453203(1.0), la oprirea din telecomanda ,,uita" tot! Am incercat cam tot ce-am gasit pe forum , inclusiv upgrade de la LG! In meniul service nu am gasit reset !
Am incercat sa descarc dumpurile de pe un  site rusesc ,dar nu reusesc ! Unde pot gasi dumpurile? Multumesc!
Link to comment
5 hours ago, Florinel TV said:
Am pus eu dumpurile de la eprom si spi , daca aveti nevoie de dumpul din nand spune si il incarc pe un sait de gazduire
LG 32LF510B-ZB MB.EAX66453203(1.0) chassis LD55B panel HC320DXN-ABNS4-5112.zip 191.06 kB · 6 downloads
Multumesc, ma ocup si va tin la curent!
Link to comment
  • 2 years later...
Join the conversation
Guest
Unfortunately, your content contains terms that we do not allow. Please edit your content to remove the highlighted words below.
Reply to this topic...
×   Pasted as rich text.   Restore formatting
  Only 75 emoji are allowed.
  • Create New...
Important Information
