iuliantv Posted December 27, 2018 Share Posted December 27, 2018 (edited) tin sa va anunt ca am si eu un asemenea display defect,defectul nu e din tcon e din display,in poza dv reeditata de mine am pus intr-un chenar negru o anumita zona cu puncte de masura in unele puncte trebuie sa apara ceva tensiuni cca 18v 29v daca acestea lipsesc decuplati banda ce vine din display in tcon in acele puncte de masura si daca apar aceste tensiuni atunci e buba in display Edited December 27, 2018 by iuliantv Quote Link to comment Share on other sites More sharing options...
asyx Posted December 27, 2018 Author Share Posted December 27, 2018 ok,multumesc.am sa fac aceste masuratori.de altfel si userul Razvan mi-a cerut acelasi lucru Quote Link to comment Share on other sites More sharing options...
asyx Posted December 28, 2018 Author Share Posted December 28, 2018 am facut masuratorile.aveti dreptate,nu am tensiuni decat dupa ce scot panglica. deci se poate arunca la gunoi Quote Link to comment Share on other sites More sharing options...
Guest Posted December 28, 2018 Share Posted December 28, 2018 Driver defect , end. Quote Link to comment Share on other sites More sharing options...
asyx Posted December 28, 2018 Author Share Posted December 28, 2018 oricum va multumesc pentru ajutor Quote Link to comment Share on other sites More sharing options...
iuliantv Posted December 28, 2018 Share Posted December 28, 2018 nu e de aruncat,cu ceva noroc poate gasiti in scurt sau cu rezistenta vre- un condesator smd pe placa dintre display si tcon Quote Link to comment Share on other sites More sharing options...
Guest Posted December 28, 2018 Share Posted December 28, 2018 Ce am spus eu era pentru nivelul de posibiltati al initiatorului . Pana nu se epuizeaza toate verificarile mai exista variante si posibilitati . Nu discutam despre posibilitatea inlocuirii driverului decfect ,care presupune si identificarea lui corecta . Este alt nivel si implica alte costuri . Quote Link to comment Share on other sites More sharing options...
asyx Posted December 29, 2018 Author Share Posted December 29, 2018 Acum 7 ore, iuliantv a spus: nu e de aruncat,cu ceva noroc poate gasiti in scurt sau cu rezistenta vre- un condesator smd pe placa dintre display si tcon am verificat deja toti condensatorii si nu am gasit nimic suspect Quote Link to comment Share on other sites More sharing options...
Join the conversation
