profimex Posted December 17, 2018 Share Posted December 17, 2018 Buna ziua am televizorul acesta care se restarteaza contiinu : Placa de baza bn41-01660B . Se poate rescrie doar memoria 24c256 pentru remediere sau trebuie rescris nandul ? Multumesc Quote Link to comment Share on other sites More sharing options...
leoncris Posted December 17, 2018 Share Posted December 17, 2018 Merita incercat .Salveaza ... originalul ! Quote Link to comment Share on other sites More sharing options...
profimex Posted December 17, 2018 Author Share Posted December 17, 2018 3 minutes ago, leoncris said: Merita incercat .Salveaza ... originalul ! gasim un dump pentru el ? Quote Link to comment Share on other sites More sharing options...
Marian Roman Posted December 17, 2018 Share Posted December 17, 2018 Acum 30 minute, profimex a spus: gasim un dump pentru el ? :: gasesti aici :: Quote Link to comment Share on other sites More sharing options...
leoncris Posted December 17, 2018 Share Posted December 17, 2018 (edited) https://electronicforum.ro/viewtopic.php?f=27&t=16240 https://www.elektroda.pl/rtvforum/topic3218763.html http://www.filehost.ro/3172936276/Samsung_UE32D5500_D5700_zip/ Edited December 17, 2018 by leoncris Quote Link to comment Share on other sites More sharing options...
Guest Posted December 17, 2018 Share Posted December 17, 2018 Acum 32 minute, Marian Roman a spus: :: gasesti aici :: Trebuie sa aiba si cont pe remont! Quote Link to comment Share on other sites More sharing options...
profimex Posted December 17, 2018 Author Share Posted December 17, 2018 multumesc am cont pe remote am cumparat si 200 de puncte ca am ramas fara am testat dumpula face la fel . Se pare ca problema este din nand . Este un coleg dispus sa ma ajute contra cost bineinteles sa trimit placa ? Programatorul meu ajunge peste 3 saptamani abia . Multumesc Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted December 17, 2018 Share Posted December 17, 2018 Acum 9 ore, profimex a spus: multumesc am cont pe remote am cumparat si 200 de puncte ca am ramas fara am testat dumpula face la fel . Se pare ca problema este din nand . Este un coleg dispus sa ma ajute contra cost bineinteles sa trimit placa ? Programatorul meu ajunge peste 3 saptamani abia . Multumesc Prima data incearca cu eepromul gol (chel) si lasal sa il scrie procesorul , apoi daca tot nu vrea atunci da jos nandul si til scriu eu , sau vorbim pe mp Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted December 17, 2018 Share Posted December 17, 2018 La mine daca trimiti placa este un pic mai greu ca am probleme acum cu mina dreapta ma cam tine muschiul si este mai greu sa dau jos nandul , dar in fine ma straduiesc si te ajut , de dat jos il dau usor dar este mai greu de pus inapoi , cind nu ma durea mina am schimbat 4 nandurii intr-o zi , adica dat jos programat pus inapoi Quote Link to comment Share on other sites More sharing options...
Guest Posted December 17, 2018 Share Posted December 17, 2018 9 hours ago, profimex said: multumesc am cont pe remote am cumparat si 200 de puncte ca am ramas fara Cat te-a costat aproximativ 200 de puncte? Quote Link to comment Share on other sites More sharing options...
megastar Posted December 17, 2018 Share Posted December 17, 2018 Probabil cam 1 dolar la 10 puncte, dar se ofera si bonus ! Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted December 17, 2018 Share Posted December 17, 2018 (edited) Eu incarc cu dumpurii si am deja 430 de puncte si cine vrea dumpui de la ei sa spuna si il ajut Edited December 17, 2018 by Florinel TV Quote Link to comment Share on other sites More sharing options...
dan cod Posted December 18, 2018 Share Posted December 18, 2018 Daca nu găsești pe altcineva pot rezolva eu cu nandul. Quote Link to comment Share on other sites More sharing options...
profimex Posted December 18, 2018 Author Share Posted December 18, 2018 10 hours ago, Costica LCD said: Cat te-a costat aproximativ 200 de puncte? 10$ + comision cam 60 lei Quote Link to comment Share on other sites More sharing options...
Guest Posted December 18, 2018 Share Posted December 18, 2018 (edited) 17 hours ago, Florinel TV said: Eu incarc cu dumpurii si am deja 430 de puncte si cine vrea dumpui de la ei sa spuna si il ajut Iseamna ca le-ai dat dumpuri rusilor fara numar, vezi ca cine descarca de la tine un dump iti da 2 puncte si iti creste nr punctelor....in schimb daca se constata ca dumpul tau nu e bun, iti scade reputatia, asa ca ai mare grija ca dumpurile sa fie verificate, la cateva comentari negative, e posibil sa nu mai descarce nimeni dumpuri de la tine, mai ales cei "saraci" care au 10-15 puncte, astia se oftica si fac urat dupa punctele pierdute.... Edited December 18, 2018 by Guest Quote Link to comment Share on other sites More sharing options...
Join the conversation
