Guest Tica Posted December 13, 2018 Share Posted December 13, 2018 Buna seara! Va rog daca ma puteti ajuta sa leg corect sirena BS1 la centrala ESIM364, multumesc! Quote Link to comment Share on other sites More sharing options...
validae Posted December 13, 2018 Share Posted December 13, 2018 Asta te-ar ajuta ? https://www.a2t.ro/source/Sirena BS1.pdf Quote Link to comment Share on other sites More sharing options...
Guest Tica Posted December 14, 2018 Share Posted December 14, 2018 Multumesc schema asta o am, oricum este gresita, este inversat - cu +, poate este cineva, care ma poate ajuta concret cum trebuie facute legaturile de la centrala ESIM 364 si aceasta sirena BS1. Multumesc foarte mult! Quote Link to comment Share on other sites More sharing options...
Catalin.tehnic Posted December 25, 2018 Share Posted December 25, 2018 Ce iesire de sirena ai la Esim ? (Bell + ,bell - ). Sirena de exterior are nevoie de alimentare + trigger (care e selectabil in functie de ce "scoate" centrala de alarma. Quote Link to comment Share on other sites More sharing options...
Join the conversation
