Guest costi001 Posted December 12, 2018 Share Posted December 12, 2018 pt acest tv sasiu a3y111-00 caut schema si ma intereseaza ce valoare are R610 nu se mai vede pe ea nimic ,va rog mult ajutatima.ms mult. Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted December 12, 2018 Share Posted December 12, 2018 http://monitor.espec.ws/section1/topic137451.html Quote Link to comment Share on other sites More sharing options...
Guest costi001 Posted December 12, 2018 Share Posted December 12, 2018 nu a3y11,imi trebuie a3y111 si cum am zis R 610 valoare asta ma intereseaza ms. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 12, 2018 Share Posted December 12, 2018 Quote Link to comment Share on other sites More sharing options...
Guest costi001 Posted December 12, 2018 Share Posted December 12, 2018 repet R610 CE VALOARE ARE .MS Quote Link to comment Share on other sites More sharing options...
Guest Posted December 12, 2018 Share Posted December 12, 2018 Vezi ce se potriveste cu schema de mai sus si spune intre ce componente este pt ca poate fi dedusa cu aproximatie. Quote Link to comment Share on other sites More sharing options...
Guest costi001 Posted December 12, 2018 Share Posted December 12, 2018 MAI STIE CINEVA ? Quote Link to comment Share on other sites More sharing options...
Guest Posted December 12, 2018 Share Posted December 12, 2018 (edited) 1 hour ago, miticamy said: Vezi ce se potriveste cu schema de mai sus si spune intre ce componente este pt ca poate fi dedusa cu aproximatie. Edited December 12, 2018 by Guest Quote Link to comment Share on other sites More sharing options...
Nostalgic Posted December 12, 2018 Share Posted December 12, 2018 (edited) deseneaza R610 pe schema postata de catre colegul -miticamy- noi nu ii stim locul (nu este desenata pe schema respectiva, si nu am la reparat acum acest sasiu a3y111). Edited December 12, 2018 by Nostalgic Quote Link to comment Share on other sites More sharing options...
cornel1962 Posted December 13, 2018 Share Posted December 13, 2018 ...puneti o poza cu sasiul si zona unde este aceasta R610. Schema postata de d-nul Miticamy este ok, sasiul a3y111 = 3y11 !!!.... , sau va pun schema completa si o cautati dvs. cand aveti timp . Spor la treaba ! PLATINIUM 54NX-PLAT (3Y11) [www.pieseelectronice.net].pdf Quote Link to comment Share on other sites More sharing options...
Nostalgic Posted December 13, 2018 Share Posted December 13, 2018 pe schema postata de dl. -miticamy- sint desenate doua rezistente denumite R611. cred ca R610 este cea denumita gresit R611 care este serie cu D604 din pin 4 traf schoper ce merge in baza Q601, si Zd602. =10k. Quote Link to comment Share on other sites More sharing options...
valangjed Posted December 13, 2018 Share Posted December 13, 2018 (edited) In schema postata de domnul miticamy sunt doua R11, una de 2,2k si una de 10k.Probabil este o greseala de tiparire si una din cele doua R11 este R10.Cautati pe sasiu R11 si masurati-i valoarea.Daca R11 are 10k inseamna ca R10 are 2,2 k, daca R11 are 2,2k inseamna ca R10 are 10k.Scuze Nostalgic! Am scris in acelasi timp. Edited December 13, 2018 by valangjed Quote Link to comment Share on other sites More sharing options...
Nostalgic Posted December 13, 2018 Share Posted December 13, 2018 (edited) Acea componenta rezistorul R610 exista pe placă , este plasată între aripile radiatorului pentru ic-ul din sursă(este prima dinspre traful de linii, daca găseam și cablajul ,treaba era rezolvata rapid). Numai autorul topicului poate rezolva , sasiul e la el pe -bancul- de lucru. În altă ordine de idei , acele două rezistențe de 10k și 2,2k ce le-au determinat să se facă scrum,și dacă diodele redresoare erau sîrmă tot nu cred că devenea scrum o rezistență de așa valoare mare. Mă rog , supoziții , păreri, Dacă autorul mai tace 24 de ore este clar că nu are rost să mai continuăm. Edited December 13, 2018 by Nostalgic Quote Link to comment Share on other sites More sharing options...
cornel1962 Posted December 14, 2018 Share Posted December 14, 2018 ... se pare ca este un fel de " tema ptr. acasa ", colegul nostru nu este foarte interesat, sau si-a rezolvat problema !!! Din punctul meu de vedere R610 este cea de 10k din circuitul aferent lui Q601 ( schema@Miticamy ),...iar in schema pe care eu am postat-o, acest Q601 lipseste ( pin 4 chopper liber ). Am solicitat o poza sa vedem si noi ce varianta are colegul nostru, dar... !!! Quote Link to comment Share on other sites More sharing options...
Join the conversation
