Kytan666 Posted July 6, 2007 Share Posted July 6, 2007 mi-a scos peri albi... am vrut sa dau drumu la 5.1 pe 4 sateliti si un bass , centralul nu ma intereseaza. setat totul corect nu merge in winamp , in jocuri merge beton, eax , super sunet .. in power dvd cu dvd orig merge , activat tot ce trebuie in winamp ..nimic in media player aveam front si bass , la un moment dat surpriza (fara sa ii fac nimic) am front si bass si in winamp , rear nimic , scot placa las onboardu realtek 7.1 nici ala nu vroia sa mearga in winamp , dau play in media player merge , dau stop dau play in winamp merge si acolo ... pun creativu inapoi nu merge , fac update de le ai pe net .. nimic , mai gasesc un update il fac si pe ala ... mergea si rear in media player dar distorsionat tare ... acum dupa ore de bifat obtiuni si debifat (aceleasi de pana acum deci nui-am facut nimic nou..)merge front , bass , si doar stanga pe rear .... plesnesc de nervi , am auzit ca , creativu are probleme cu drivere , adica doar unele vers merg ... si nu las onboardu ca nu stie de nimic .. pe audigy am 24 biti , am crossover , eax2 ... cabluri , amplificari totul e bun .. eu am ramas fara idei :axe: Link to comment
Guest Timofte Silviu Posted July 6, 2007 Share Posted July 6, 2007 incearca asa (cel putin la mine a mers) din winamp-->options-->preferences-->Output-->selecteaza DirectSound-->Configure-->Device-->selecteaza placa ta de sunet (vezi sa fie bifat "allaw hardware acceleration" -->Ok restart winamp si ar cam trebui sa mearga. Din setarile placii de sunet sa fie 5.1.O zi buna Link to comment
Kytan666 Posted July 6, 2007 Author Share Posted July 6, 2007 asta e primu lucru facut , tot ce tine de setari , e facut , m-am documentat pe net inainte sa postez .. deocamdata merge fara un rear . Link to comment
Sonic Posted July 7, 2007 Share Posted July 7, 2007 Incearca cu optiunea Stereo Surround, asa trebe sa ai sunet in toate boxele. Link to comment
Kytan666 Posted July 7, 2007 Author Share Posted July 7, 2007 cu acea optiune am sunet de acuma , oricum , am sa ma reprofilez pe alta firma si gata , creative au o gramada de probleme cu driverele .. si un suport de 2 lei .. la update vroia sa-mi bage drivere de sb live lol .. merge dar fara eax .. Link to comment
margarit2001 Posted July 26, 2007 Share Posted July 26, 2007 cu mai multe modele de la acest producator am avut probleme nu ca nu ar fi bune ci prin faptul ca driverele erau varza pana cand am gasit: http://www.kxproject.com :prayer: apoi totul se rezolva imediat, fara driverele fabrica adica fara batai de cap, :supz: Link to comment
