radu25 Posted July 2, 2007 Share Posted July 2, 2007 Am instalat Ubuntu 7.04. Nu puteam mari rezolutia mai mult de 800x600.In xorg.conf nu aveam abtiunea 1024x768.Am intrat ca root si am editat xorg.conf sa ma si rezolutia asta.Dupa reboot nu se mai vedea nimic si monitorul imi spunea "wrong resolution"Am editat xserver cu:sudo dpkg-reconfigure xserver-xorgTot degeaba! Eroare: no screen found!Ce mai pot face?P.S. Celeron 2G; 512Mram; palca video integrata intel graphics 845. Link to comment Share on other sites More sharing options...
LostCell Posted July 2, 2007 Share Posted July 2, 2007 ma gandesc ca poate trebuie sa te loghezi cu "root" si sa dai dpkg-reconfigure xserver-xorg din moment ce ai fost logat cu root cand l-ai modificat. si eu am patit asa si a mers perfect cu ea.sau daca ai drivere la video instaleazale din consola.sau booteaza de pe cd ubuntu si stergi modificarile care le-ai facut la xorg.conf(reeditezi) Link to comment Share on other sites More sharing options...
radu25 Posted July 2, 2007 Author Share Posted July 2, 2007 oko sa reinstalez X de pe Cd. Nu mai ca o sa ajung la aceeasi problema: Rezolutia maxima 800x600 iar refresh=60.cum pot mari rezolutia si refreshu fara sa stric din nou xorg? Link to comment Share on other sites More sharing options...
radu25 Posted July 4, 2007 Author Share Posted July 4, 2007 asa arata xorg.Cum il modific?# /etc/X11/xorg.conf (xorg X Window System server configuration file)## This file was generated by dexconf, the Debian X Configuration tool, using# values from the debconf database.## Edit this file with caution, and see the xorg.conf(5) manual page.# (Type "man xorg.conf" at the shell prompt.)## This file is automatically updated on xserver-xorg package upgrades *only*# if it has not been modified since the last upgrade of the xserver-xorg# package.## If you have edited this file but would like it to be automatically updated# again, run the following command:# sudo dpkg-reconfigure -phigh xserver-xorgSection "Files" FontPath "/usr/share/fonts/X11/misc" FontPath "/usr/share/fonts/X11/cyrillic" FontPath "/usr/share/fonts/X11/100dpi/:unscaled" FontPath "/usr/share/fonts/X11/75dpi/:unscaled" FontPath "/usr/share/fonts/X11/Type1" FontPath "/usr/share/fonts/X11/100dpi" FontPath "/usr/share/fonts/X11/75dpi" # path to defoma fonts FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"EndSectionSection "Module" Load "i2c" Load "bitmap" Load "ddc" Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "vbe"EndSectionSection "InputDevice" Identifier "Generic Keyboard" Driver "kbd" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "us"EndSectionSection "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "true"EndSectionSection "InputDevice" Driver "wacom" Identifier "stylus" Option "Device" "/dev/input/wacom" Option "Type" "stylus" Option "ForceDevice" "ISDV4" # Tablet PC ONLYEndSectionSection "InputDevice" Driver "wacom" Identifier "eraser" Option "Device" "/dev/input/wacom" Option "Type" "eraser" Option "ForceDevice" "ISDV4" # Tablet PC ONLYEndSectionSection "InputDevice" Driver "wacom" Identifier "cursor" Option "Device" "/dev/input/wacom" Option "Type" "cursor" Option "ForceDevice" "ISDV4" # Tablet PC ONLYEndSectionSection "Device" Identifier "Intel Corporation 82845G/GL[brookdale-G]/GE Chipset Integrated Graphics Device" Driver "i810" BusID "PCI:0:2:0"EndSectionSection "Monitor" Identifier "Generic Monitor" Option "DPMS" HorizSync 28-40 VertRefresh 43-60EndSectionSection "Screen" Identifier "Default Screen" Device "Intel Corporation 82845G/GL[brookdale-G]/GE Chipset Integrated Graphics Device" Monitor "Generic Monitor" DefaultDepth 24 SubSection "Display" Depth 1 Modes "800x600" "720x400" "1x1" EndSubSection SubSection "Display" Depth 4 Modes "800x600" "720x400" "1x1" EndSubSection SubSection "Display" Depth 8 Modes "800x600" "720x400" "1x1" EndSubSection SubSection "Display" Depth 15 Modes "800x600" "720x400" "1x1" EndSubSection SubSection "Display" Depth 16 Modes "800x600" "720x400" "1x1" EndSubSection SubSection "Display" Depth 24 Modes "800x600" "720x400" "1x1" EndSubSectionEndSectionSection "ServerLayout" Identifier "Default Layout" Screen "Default Screen" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" InputDevice "stylus" "SendCoreEvents" InputDevice "cursor" "SendCoreEvents" InputDevice "eraser" "SendCoreEvents"EndSectionSection "DRI" Mode 0666EndSection Link to comment Share on other sites More sharing options...
radu25 Posted July 4, 2007 Author Share Posted July 4, 2007 Am rezolvat cu reconfigure x server.Inainte nu mergea pt ca eu distrusesem deja xorg. Dar acum cu un nou xorg amers cu: sudo dpkg-reconfigure.........etc.O sa incerc si cum ai zis tu, pt ca am refreshu 60Hz si vreau sa-l aduc la 85.Merci! Link to comment Share on other sites More sharing options...
radu25 Posted July 4, 2007 Author Share Posted July 4, 2007 Gata! am rezolvat si cu refreshu.Merci mult! Link to comment Share on other sites More sharing options...
MifTy Posted July 5, 2007 Share Posted July 5, 2007 BSD mai are un avantaj: poti sa recompilezi toate aplicatiile cu specificatiile procesorului. De-aia io pe celeron la 300 MHz io vad DivX si DVD. Linux vine cu totul pre-compilat ca sa functioneze si pe intel si pe AMD. Cu autodetectare daca are MMX, MMX2 sau 3dnow. rezulta ca aplicatiile ocupa mult pe harddisk pentru ca contin instructiuni pentru toata gama de procesoare. Cele mai multe o sa lucreze cu setul standard x86. Daca compilam mplayer cu specificatiile strict pentru pentium III, atunci o sa-l foloseasca la capacitatea maxima, cu instructiunile toate si standard si specifice. Programul ala compilat n-o sa mearga pe P-2, sau o sa mearga partial. Pe AMD imediat o sa dea core dump. Dar pe vechea rabla poti vedea filme. Si pe linux e posibil, dar nu stiu exact cum se face, si foarte putini stapanesc tehnica. Io raman cu BSD.poţi recompila kernelul linux astfel încât să fie optimizat pentru un procesor anume. doar că după aia mai tre' şi gcc-ul, şi librăriile, şi aplicaţiile să fie compilate cu aceleaşi optimizări ca să iasă cum trebuie toată boscăria... aşa că mai bine iei gentoo şi gata :yawinkle: xBSD are mai toate aplicaţiile portate de pe linux, inclusiv xorg-ul... şi kde/gnome/fluxbox/xfce/ce_mai_vrei_tu, practic nu prea există aplicaţii scrise pentru cevaBSD anume!diferenţa dintre linux si BSD e tipul de kernel si sistemul de fişiere. nu mă refer la fat/ext3/alte_alea, ci la structura directoarelor în root, structură SystemV (structură concepută tot la Berkeley...), spre deosebire de cea linux, mai apropiată de minix (la urma urmei, Torvalds a vrut să porteze minix pe PC, nu să creeze un sistem de operare nou!!!)dacă te doare mintea să foloseşti o vechitură gen mmx/233 cu 64 de mega de ram şi o placă video oarecare (dar să aibă măcar 8 mega de ram... şi să nu fie vre-un SiS!!!), ca dvd-player, ia vezi cum stă treaba cu movix/e-movix. (pagina principală e în update acum, aşa că am dat link spre secţiunea de download...) Link to comment Share on other sites More sharing options...
MifTy Posted July 6, 2007 Share Posted July 6, 2007 auzi... io am văzut şi nişte plăci 386 ştiind să booteze de pe cd (unicat chestiune, dar sper c-ai priceput ce vreau să spun cu asta, totuşi...).aşa că taci, scrie-ţi cd-ul, şi dă-mi o bere!!! :snakeman: :partyman: Link to comment Share on other sites More sharing options...
Archived
