vl78stc Posted August 14, 2017 Share Posted August 14, 2017 este echipat cu STRF6653 alimentare,24c16, tda 12020H1/N1B01 smd iar trafo lini a0 2404;11425106C C04;50H0000204 asa scrie pe trafo lini si nu stiu ce ehivalent are pe placa scrie CP520A main, tv a avut siguranta alim scc si STRF schimbat,tv a pornit dar dupa citeva minute 2-4 se opreste imaginea nu mai am filament si inalta am sonor si in trafo se aud descarcari iar cind am un pic de imagine se vad zimtarile pe imagine dupa care imagine neagra.am schimbat condensatorii 47uf/160v.10uf/250v,4,7uf/250v refacut lipituri trafo lini si bobine deflexie (mufa), as dori in echivalent pentru trafo lini eu nu am gasit multumesc Link to comment
surubarila Posted August 14, 2017 Share Posted August 14, 2017 (edited) Sanatate permanenta ! Cauta 1352.5060 , este codul din schema CP520. Sau scoate-l , fa-i o poza si indica pe fiecare pin unde e legat- B+ , U video , filament etc. Edited August 14, 2017 by surubarila Link to comment
Florinel TV Posted August 14, 2017 Share Posted August 14, 2017 (edited) Schimba si C401 100mf din driver si C440 0,024mf 400V Edited August 14, 2017 by Harhas Florin Link to comment
BUGHIU Posted August 14, 2017 Share Posted August 14, 2017 In functie de tub putem sti ce traf merge.... Link to comment
vl78stc Posted August 15, 2017 Author Share Posted August 15, 2017 tub normal nu plat Link to comment
BUGHIU Posted August 15, 2017 Share Posted August 15, 2017 FBT 8537 ...si echivalentele !! Link to comment
