costy Posted August 10, 2017 Share Posted August 10, 2017 Pe scurt, porneste, apare sigla pfilips, apare nr unui canal si ramane blocat, nu mai raspunde la comenzi. Daca sunt rapid si apas meniu intre afisarea siglei si afisarea canalului, apare meniul dar dispare repede si ramane blocat Banuiesc ca e softul dar cum sa-l rescriu? Link to comment
dan cod Posted August 10, 2017 Share Posted August 10, 2017 Trebui incercat pe USB problema este sa gasesti softul bun. Link to comment
costy Posted August 10, 2017 Author Share Posted August 10, 2017 in ce sens softul bun? nu merge cu unul de pe site? Link to comment
dan cod Posted August 10, 2017 Share Posted August 10, 2017 Daca e ok va merge daca nu nu. Link to comment
costy Posted August 10, 2017 Author Share Posted August 10, 2017 am incercat asa: am pus autorun.upg pe un stick de memorie formatat fat32 apoi l-am pus intr-un usb si am bagat tv in priza, dar degeaba, il ignora Mai e vreo procedura ce o pot incerca? Link to comment
dan cod Posted August 10, 2017 Share Posted August 10, 2017 Incearca sa redenumesti .pkg Link to comment
costy Posted August 10, 2017 Author Share Posted August 10, 2017 a mers asa oarecum. Apare un ecran cu o bara de incarcare ce se incarca rapid pana la jumatate apoi ramane blocat asa Deci in mintea mea ori e defecta memoria unde e stocat firmware, ori ram ori procesor Banuiesc ca acum pot exclude firmware defect, sau e inca in carti? Link to comment
