claudiu68 Posted August 7, 2017 Share Posted August 7, 2017 va salut acest tv. restarteaza permanent....are cineva un soft probat pentru el ? multumesc Link to comment
Guest Posted August 7, 2017 Share Posted August 7, 2017 (edited) Daca nu pleaca de pe stick redenumeste fisierul in "Upgrade.pkg" https://files.fm/u/5tssassz#_ http://philips-tpv.blogspot.ro/2017/03/32pfl3088h12-restarteaza-continuu-soft.html Edited August 7, 2017 by Guest Link to comment
claudiu68 Posted August 7, 2017 Author Share Posted August 7, 2017 am incercat toate variantele ....nu vrea apare sigla philips .. dispare.. etc. Link to comment
FLORIN IORDACHE Posted August 7, 2017 Share Posted August 7, 2017 am incercat toate variantele ....nu vrea apare sigla philips .. dispare.. etc. Dati-ne si noua mai multe date despre acest tv-u . Adica cum ar fi : Model : sursa, Model : main board, Model : display.... Asteptam !!! Link to comment
claudiu68 Posted August 8, 2017 Author Share Posted August 8, 2017 are o singura placa...acolo face tot ...ar trebui demontat tot ca sa vad seria panoului Link to comment
dan cod Posted August 8, 2017 Share Posted August 8, 2017 Dati-ne si noua mai multe date despre acest tv-u . Adica cum ar fi : Model : sursa, Model : main board, Model : display.... Asteptam !!! Nu ajuta la nimic asta Florine.Ii trebuie soft ok. Link to comment
FLORIN IORDACHE Posted August 8, 2017 Share Posted August 8, 2017 Nu ajuta la nimic asta Florine.Ii trebuie soft ok. Ok,am inteles ! Atunci trebuie sa astepte un soft bun. O zi minunata va doresc !!! Link to comment
gabilungu66 Posted August 8, 2017 Share Posted August 8, 2017 (edited) Cu acest soft am rezolvat un tv identic, care tot la fel se restarta. In postul #7 gasesti link-ul de directionare si bin-ul care se gaseste la pozitia 2. http://www.elforum.info/topic/123022-philips-32pfl3168h12-update-usb/ Edited August 8, 2017 by gabilungu66 Link to comment
Sorin Schiriac Posted August 9, 2017 Share Posted August 9, 2017 daca nandul are baduri multe nu merge resoftarea cu pkg numai prin recuperare soft nand si rescrierea pe un alt nand Link to comment
gabilungu66 Posted August 10, 2017 Share Posted August 10, 2017 Asa este, dar merita incercat. La mine a mers din prima. Link to comment
iuliantv Posted July 20, 2019 Share Posted July 20, 2019 (edited) cele de aici nu merg? http://philips-tpv.blogspot.com/2017/03/32pfl3088h12-restarteaza-continuu-soft.html citez Costica lcd ,,Daca nu pleaca de pe stick redenumeste fisierul in "Upgrade.pkg" Edited July 20, 2019 by iuliantv 1 Link to comment
surubarila Posted July 21, 2019 Share Posted July 21, 2019 Acum 19 ore, iuliantv a spus: cele de aici nu merg? http://philips-tpv.blogspot.com/2017/03/32pfl3088h12-restarteaza-continuu-soft.html citez Costica lcd ,,Daca nu pleaca de pe stick redenumeste fisierul in "Upgrade.pkg" Va salut ! Un defect asemanator am si eu , link-ul postat de dvs. imi descarca un document HTML la deschiderea caruia ma trezesc pe un site de "friki-friki"...Detalii despre ce am incercat cititi mai jos : https://www.elforum.info/topic/117285-philips-32pfl3088h12-se-restarteaza/page/3/?tab=comments#comment-1802136 Va rog daca aveti vreun firmware testat , multumesc ! Link to comment
iuliantv Posted July 21, 2019 Share Posted July 21, 2019 (edited) Acum 33 minute, surubarila a spus: Va salut ! Un defect asemanator am si eu , link-ul postat de dvs. imi descarca un document HTML la deschiderea caruia ma trezesc pe un site de "friki-friki"...Detalii despre ce am incercat cititi mai jos : https://www.elforum.info/topic/117285-philips-32pfl3088h12-se-restarteaza/page/3/?tab=comments#comment-1802136 Va rog daca aveti vreun firmware testat , multumesc ! scuze eu acum am verificat,nu e vina mea ,asa se intampla cand expira linkul baga reclame http://www.fileshare.ro/e3172791953 Edited July 21, 2019 by iuliantv Link to comment
