Jump to content
Sign in to follow this
Guest a/3
panasonic tx-21s4tp
Guest a/3
tv-ul nu prinde posturile se vede ceva vag desincronizat parca ar fi in ntsc .am gasit selectorul cu tensiunea de 33v zero scurt pe sel,schimbat sel cu dt5-bf18d
Share this post
Link to post
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
