robert1000 Posted July 18, 2017 Share Posted July 18, 2017 (edited) Va salut cu respect! Este vorba de un tv lcd teletech model 32715, sasiu 17mb22-2. Am gasit niste electrolitici umflati in sursa, i-am schimbat. Tv iese din stand-by - uneori functioneaza ceva vreme pana cand moare ba o lampa din josul ecranului, ba 3-4 de sus. Nu cred ca e vreo lampa defecta, le-am urmarit si nu vad ca palpaie vreuna... Insa mi se pare ciudat ca uneori se opresc in acelasi timp vreo 4 lampi de sus (si bineinteles ca intra in protectie). Cand se opresc acele lampi, chiar daca repornesc repetat tv-ul, se vede zona de sus neluminata si backlight-ul se opreste rapid. Daca desfac placa invertor si ma joc putin cu lampile, apoi se aprind!! Poate sa fie unul din trafuri invertor defect? Sa fie legaturile lampilor imperfecte (daca nu ma insel sunt legate cate doua in serie) ? Se merita sa desfac displayul? Cuplele invertorului de pe lampi m-am asigurat ca fac contact cum trebuie. Idei ? Edited July 19, 2017 by robert1000 Link to comment
robert1000 Posted July 19, 2017 Author Share Posted July 19, 2017 Pe placa invertor scrie ss1320wa16. Are 4 trafuri lt3224. Link to comment
dan cod Posted July 19, 2017 Share Posted July 19, 2017 Ai masurat trafurile sa fie infasurarile secundare identice? Link to comment
BUGHIU Posted July 19, 2017 Share Posted July 19, 2017 (edited) ....si intarite lipiturile la pini trafo si nu numai,daca sant ok ohmetric,eventual verificat conectori lampilor .....trasee,etc Edited July 19, 2017 by BUGHIU Link to comment
robert1000 Posted July 19, 2017 Author Share Posted July 19, 2017 (edited) Am facut toate astea...degeaba. Mentionez ca uneori sursa bazaie (chopper). Nu cred ca e normal, bazaie urat...ce determina acest fenomen la aceasta sursa? Pe cond mare am 320v in stand-by, 330v in functionare. E normal? Tensiunile 5v, 24v, 3,3...corecte. Pareri? Inca ceva... cand tv porneste fara bazait chopper, am pe cond mare in functionare 430v. Cand merge cu bazait scade la 330v. Ma gandesc ca bazaitul si tensiunea scazuta indica consum mare....pe invertor? Pai si de ce merge cand asa cand asa? Ma lamureste careva? Ce pot sa ii fac? Edited July 19, 2017 by robert1000 Link to comment
winstyle Posted July 19, 2017 Share Posted July 19, 2017 Când nu mai ai cei 400 volți , inseamnă că se oprește PFC-ul .Se opreste PFC-ul ,se oprește și convertorul care alimentează invertorul (dacă are acel tip de sursă de care știu eu ) Te-ai ''dus'' direct la invertor .Problema pare să fie in sursă . Link to comment
robert1000 Posted July 19, 2017 Author Share Posted July 19, 2017 E sursa cu sg3525a, p1014ap06...nu vad seria ei. Uneori vad ca chopper bazaie chiar si cand pe cond mare e 430v. Chiar si cand am 330v, am cei 24v alimentare invertor. Unde sa ma uit? Link to comment
robert1000 Posted July 19, 2017 Author Share Posted July 19, 2017 Am pus multimetrul pe condul mare si l-am lasat fixat acolo. Observatii : - 320v in stand by. Apas butonul, tensiunea se ridica la 430-440v apoi pornesc lampile. - uneori raman cei 430v dupa pornirea lampilor, alteori scad la 330v si chopper bazaie. - uneori sursa porneste in liniste, alteori trafo chopper bazaie. Electroliticii schimbati toti. Initial cei de 1000/16 erau umflati. C877 si C878 sunt maro, nu albastrii. Ati avut asa defect? Ce ii pot face? Link to comment
winstyle Posted July 19, 2017 Share Posted July 19, 2017 Caută mai bine seria sursei .Nu se poate să nu o găsești . Poate este acoperită cu ceva . Am avut un astfel de caz in care seria sursei era acoperită cu un fel de rășină albă , sau vopsea ... nu știu exact ce era . Link to comment
orgasmo Posted July 19, 2017 Share Posted July 19, 2017 Caută mai bine seria sursei . Posibil 17PW20 V1 http://www.elforum.info/topic/119529-lcd-teletech-32715/ Link to comment
robert1000 Posted July 19, 2017 Author Share Posted July 19, 2017 Am gasit seria. Era niste silicon pe ea. Este 17pw15-9. Deci recapitulare : Tv porneste. Uneori porneste in liniste, alteori porneste cu chopper bazaind (consum marit??) Cu mufa invertor scoasa, sursa nu bazaie. Uneori, dupa vreo 30 min de functionare, partea de sus a ecranului devine slab luminata (desi toate lampile se aprind...dar cele de sus probabil in acel moment se aprind mai slab) si tv opreste backlight-ul in cateva secunde. Misc placa invertoare si apoi o ia. Cuplele invertor-lampi m-am asigurat ca fac contact cum trebuie. Pe cond mare in functionare ba e 430v , ba e 330v. Condensatorii electrolitici toti schimbati. Tensiuni secundare sursa bune! Ce-i pot face? Link to comment
winstyle Posted July 20, 2017 Share Posted July 20, 2017 Pentru inceput refacerea lipiturilor care arată suspect . Link to comment
dan cod Posted July 20, 2017 Share Posted July 20, 2017 Eu zic că PFCul e acolo cauza nefunctionarii ok. Link to comment
cristybadea Posted July 20, 2017 Share Posted July 20, 2017 Vezi daca se pupa http://www.elforum.info/topic/120317-lcd-hitachi-model-32ld8600-a/ Link to comment
